July 15, 2019, 03:53 |
Error Message while implementing PANS turbulence model
#21 | |
Ketan Ganatra
Rep Power: 9 |
I have attached the following image for error message. Could you help me regarding this..??? Please.. Thank you.... |
July 16, 2019, 16:22 |
Error messgae while compiling PANS turbulence model in ubuntu
#22 |
Raj Kiran
Rep Power: 8 |
Hello Foamers,
I have tried the Allwmake command as explained in terminal after pasting the contents of the clone (find root)folder. But am facing few errors which are shown in the images. Please guide me through this errors. Thanks and regards, Raj Kiran. |
July 17, 2019, 03:32 |
#23 |
sajad alimardani
Rep Power: 8 |
hi
what your version openfoam? 6 !? this proram just working for openfoam 3.0.1 and 3 . Helio Also write pans code for openfoam 4 . https://github.com/HelioVillanueva/helio-4.x regards, sajjad |
July 17, 2019, 04:10 |
#24 | |
Raj Kiran
Rep Power: 8 |
July 17, 2019, 04:22 |
#25 |
sajad alimardani
Rep Power: 8 |
hi Raj Kiran.
I don't know exist pans code for version 6. you must change code pans for OF6. code OF versions Some changes. Helio is better able to help you. regards, sajjad |
August 6, 2019, 12:44 |
Error message while installing openfoam extended 3 for PANS turbulence models..
#26 |
Ketan Ganatra
Rep Power: 9 |
Can any one help me regarding the error message mentioned in the image???
the error message appears as "Command not found". |
August 7, 2019, 14:58 |
#27 |
sajad alimardani
Rep Power: 8 |
February 27, 2020, 19:11 |
#28 |
Pedro
Rep Power: 10 |
Sorry for the late reply. This comment might help people who are using PANS.
PANS absolutely captures the transition point. It all depends on i) your numerical and physical resolutions ii) inflow field iii) imposing right unstable modes! If more help is needed please let me know. |
February 27, 2020, 19:12 |
#29 | |
Pedro
Rep Power: 10 |
Sorry for the late reply. This comment might help people who are using PANS. PANS absolutely captures the transition point. It all depends on i) your numerical and physical resolutions ii) inflow field iii) imposing right unstable modes! If more help is needed please let me know. Pedram |
July 13, 2020, 14:30 |
#30 |
Gang Wang
Rep Power: 8 |
I think it's an old post but I'd like to know could anyone share the revised code of PANS model for OpenFOAM v1806 or the latest version of OF?
Best, Gang |
February 6, 2021, 22:07 |
#31 |
Skanda
Rep Power: 5 |
Is there revised code for OoenFOAM v2012? Badly need the PANS code.
September 27, 2021, 09:42 |
#32 |
Gang Wang
Rep Power: 8 |
September 28, 2021, 07:29 |
#33 |
Skanda
Rep Power: 5 |
September 28, 2021, 07:54 |
#34 | |
Gang Wang
Rep Power: 8 |
Thank you very much for sharing the code. I mainly use the kOmegaSST-PANS. It's really great to test your code. My Email is wg0632@gmail.com. Let's keep in touch. Best regards, Gang |
December 11, 2021, 15:46 |
#35 | |
CPark
Rep Power: 5 |
Could you share the code with me as well? It'll be greatly appreciated. Here is my email: ckdrb247@mail.com Thanks in advance. With kind regards, ck |
December 27, 2021, 11:23 |
#36 |
dd
Hi, Foamers,
I see that many people here want a PANS turbulence code that running on recent OpenFOAM distributions. Early this year (2021), I managed to compile the PANS code originally written by HelioVillanueva on OpenFOAM-v2012 , the modified PANS code can be found on https://github.com/oseen/PANS_TurbulenceModels. The code was confirmed to work on OpenFOAM-v2012 and OpenFOAM-v2106. Best regards, |
December 28, 2021, 11:04 |
#37 | |
CPark
Rep Power: 5 |
Is the k-epsilon PANS model based on Maximum Transport (MT) model (Girimaji, 2006)? Or is it based on the Zero Transport (ZT) model? The k-epsilon model used by OpenFOAM and HelioVillanueva differ from the classical k-epsilon model used in Girimaji (2006) so I find it hard to trace back Heliovillanueva's derivation. Thanks in advance! With kind regards, ck |
July 31, 2023, 10:49 |
compilation problem
#38 | |
Pallav Sahu
Rep Power: 3 |
Hi i tried to compile this code in OpenFOAM-v2012 but getting this error Traceback (most recent call last): File "/usr/lib/command-not-found", line 28, in <module> from CommandNotFound import CommandNotFound File "/usr/lib/python3/dist-packages/CommandNotFound/CommandNotFound.py", line 19, in <module> from CommandNotFound.db.db import SqliteDatabase File "/usr/lib/python3/dist-packages/CommandNotFound/db/db.py", line 5, in <module> import apt_pkg ImportError: /opt/OpenFOAM/OpenFOAM-v2012/ThirdParty/platforms/linux64/gcc-6.3.0/lib64/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /lib/x86_64-linux-gnu/libapt-pkg.so.6.0) pallav@Pallav-ideapad:~/OpenFOAM/pallav-dev/PANS_TurbulenceModels-master/src/TurbulenceModels$ can you help me with directing what's going wrong in my compilation Best regards Pallav |
August 4, 2023, 02:58 |
#39 | |
Pallav Sahu
Rep Power: 3 |
June 23, 2024, 08:13 |
#40 |
Faiz Azhar Masoodi
Rep Power: 5 |
Hi.. I am using your codes. While ke formulation takes the limits for fk as expected, kw does not. could you please help?
different zones, different turbulence models | gmwsy | FLUENT | 5 | June 17, 2020 16:42 |
in k-epsilon wall function approach high Re turbulence models: question of velocity | romant | OpenFOAM Programming & Development | 6 | May 26, 2016 10:14 |
Y plus for various turbulence models | taram | CFX | 8 | December 16, 2013 12:44 |
Zero Equation Turbulence models | stefan.gracik | OpenFOAM Programming & Development | 3 | April 17, 2013 15:12 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 11:26 |
