openfoam define a zero value volscalarfield
Old   February 4, 2016, 09:00
Default openfoam define a zero value volscalarfield
Luis Lencina
LUIS1717 is on a distinguished road
Hi everyone,
I'm trying to program a solver and its need a volscalarfield that initially must be zero everywhere in the mesh and I don't want to read it from any initial condition or to write it down. Anyone know how to do it?
thanks in advance Luis
LUIS1717 is offline   Reply With Quote
Old   February 4, 2016, 11:26
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Just an example:
$ sol
$ grep -r volScalarField *
...lots of output...
stressAnalysis/solidDisplacementFoam/readThermalProperties.H
$ less stressAnalysis/solidDisplacementFoam/readThermalProperties.H
Go to line 16.
Another:
$ src
$ cd turbulenceModels/incompressible/turbulenceModel/laminar
$ less laminar.C
Go to line 90 (this one maybe a little bit too complicated, since involves certain things in addition to field creation).
alexeym is offline   Reply With Quote
Old   February 4, 2016, 11:57
Luis Lencina
Thanks alexeym,
I was wondering if there were some way to avoid to create the IOobject, or at least dont have to write it down.
Old   February 4, 2016, 11:58
Smile
Hesam
rapierrz is on a distinguished road
Hi Luis,
For example for vol scalar field alpha
volScalarField Temp
IOobject
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
dimensionedScalar("Temp",dimensionSet(0,0,0,0,0,0, 0),0)
rapierrz is offline   Reply With Quote
Old   February 4, 2016, 12:22
Alexey Matveichev
@LUIS1717
If you take a look at GeometricField class documentation (http://foam.sourceforge.net/docs/cpp/a00912.html, volScalarField is just a typedef GeometricField<scalar, fvPatchField, volMesh>), it can be created either as a copy of another GeometricField, or on the base of IOobject.
So in brief, no, you can not avoid IOobject constructor.
Surely if you really-really-really hate IOobject constructor, you can create wrapper taking field name, dimensions, and mesh as parameters and returning autoPtr.
Old   April 16, 2016, 16:16
ziad is on a distinguished road
Originally Posted by LUIS1717 View Post
Hi everyone,
Here's a REALLY ugly hack, but it's simple, it works and you won't need IOobject.
volScalarField toto ("use any combination of variables with correct dimensions");
toto *= scalar(0);
ziad is offline   Reply With Quote
openfoam, volscalarfield, zero value
Hydrogen storage by metal hydride longbk FLUENT 12 August 1, 2023 21:13
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 22:13
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 20:00
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 14, 2016 11:19
Different define of psi uesd in pEqn.H zqlhzx OpenFOAM Running, Solving & CFD 0 December 24, 2013 09:45
