February 2, 2016, 02:46 |
how to specify velocity component(Ux, Uy) in turbulence model?
Seokwon Whang
Rep Power: 14 |
Dear Foamer,
Recently, I tried to make turbulence model, Lam-Bremhorst k epsilon which is low-reynolds number model. (OF 2.3) When the energy equation is introduced, extra source terms should be considered, S = C3(epsilon/k)Gk, where C3 = tanh |v/u|. I wonder how can I define the 'v' and 'u' in the source code. (LamBremhorstKE.H and .C) Thank you, Last edited by hswzzz; February 2, 2016 at 22:12. |
February 3, 2016, 19:58 |
Rep Power: 12 |
if u and v are the components of the velocity-field, it should be something like: volScalarField u = U_.component(0); regards, teuk |
Error message: Insufficient Catalogue Size | Paresh Jain | CFX | 33 | August 16, 2024 06:09 |
gamma-ReTheta turbulence model for predicting transitional flows | FelixL | OpenFOAM Programming & Development | 123 | August 30, 2022 12:50 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 07:08 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
