January 29, 2016, 13:25 |
Solve in Region0 then Region1
Ali
Rep Power: 13 |
Hi
Does anyone know how to alter a solver so that it solves in 2 (or more) stages, i.e region1, then region2? I'm having trouble defining a region in the .C file. I've tried to copy the way chtMultiRegionFoam does it, but with little success. I'm not sure where it defines the regions in the solver. I can see where it does in the case. Any help is appreciated! Ali |
January 29, 2016, 17:51 |
David Gaden
Rep Power: 22 |
createRegionProperties.H reads the regionProperties and holds information about the regions. Look at this file and you will see what it does and what class it uses.
CHT solvers create a separate mesh for each region. This is in createFluidMeshes.H. They create fields on each mesh in createFluidFields.H, and they set references before running the solver algorithm in setFluid something or other. Can't remember. The algorithm is run in solveFluid.H I think. In your case directory, each 'instance' can have a region subdirectory. By instance, I mean 'constant', 'system', or time directories. This is where each region stores its information. Hope this helps.
~~~ Follow me on twitter @DavidGaden |
February 1, 2016, 11:26 |
Ali
Rep Power: 13 |
Thanks David.
I'll take a look at those files. It's still quite difficult applying those things from the CHT solver to my own one! Also, I don't think createRegionProperties.H exists. Last edited by ali.m.1; February 1, 2016 at 12:32. |
solve equation | michaelsmit | OpenFOAM Running, Solving & CFD | 4 | March 24, 2011 06:35 |
Solve Flow or VOF simultaneously ? | Ramsey | FLUENT | 1 | February 16, 2011 14:16 |
Linearized NS euqations: how to solve them?(problem with Matrix operations..) | matteoL | OpenFOAM Running, Solving & CFD | 0 | November 18, 2009 07:58 |
Using Compressible Solver (sonicFoam) to solve subsonic flows | ezsoal | OpenFOAM | 0 | October 27, 2009 10:13 |
MAC method solve for pressure at boundry | Ron | Main CFD Forum | 2 | January 28, 2006 03:14 |
