Customized Sutherland transport
Old   January 29, 2016, 13:16
Default Customized Sutherland transport
Francesco Capuano
francesco_capuano is on a distinguished road
Dear all,
I am trying to customize the equation used to calculate the thermal conductivity when employing the Sutherland model. Apparently, OpenFOAM adopts the so-called modified Euken model, that is implemented in line 149 of (version 2.4):
thermophysicalModels/specie/transport/sutherland/sutherlandTransportI.H
template<class Thermo>
inline Foam::scalar Foam::sutherlandTransport<Thermo>::kappa
    const scalar p, const scalar T
) const
    scalar Cv_ = this->Cv(p, T);
    return mu(p, T)*Cv_*(1.32 + 1.77*this->R()/Cv_);
However, any modifications of these lines do not seem to have any effect on the results. I am compiling the modified library by executing wmake in the Sutherland directory, and I am checking the kappa field by adding the following lines to createFields.H in my solver:
volScalarField kappa = thermo.kappa();
kappa.write();
The field of kappa remains unchanged to any modification in the formula.
What's wrong with this?
Thanks in advance for any suggestions.
francesco_capuano is offline   Reply With Quote
Old   January 29, 2016, 17:59
David Gaden
marupio is on a distinguished road
Are you sure the code you are editing is the code that is compiling, and are you sure the code that is compiling is the code you are linking to / running?
You could insert an obvious line in there:
Info << "Test line!" << endl;
If you don't see that get posted to the console, then you know you are not editing what you are running.
Sometimes old binaries have a habit of kicking around and messing things up. Try:
$ which nameOfApplicationYouAreRunning
e.g. $which blockMesh
Then:
ls -al outputOfLastCommand
This will tell you when your executable was modified last. Also, search for the .so that you are linking to. libspecie.so... I think. Check the date on that one. Check for multiples.
Another question, you are modifying the specie library, and then you are testing by calling the thermo object's kappa. The specie library returns only a single cell value. Thermo's kappa returns a full field. When does it do a forAll(cells) and update the kappa? Are you testing when it hasn't updated yet?
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   February 1, 2016, 14:06
Francesco Capuano
Dear David, thanks for your suggestion.
I had already tried your hints. It's weird. The libspecie.so library appears as modified, but debugging messages are not displayed. I'm not sure whether the application is actually calling the specie's kappa function or not...
sutherland transport, thermal conductivity
Customized Monitor ashish_kumar388 FLUENT 0 December 1, 2014 04:01
Problems running customized solver for diffusion mmkr825 OpenFOAM Running, Solving & CFD 1 August 30, 2012 15:01
customized sonicFoam for adaptive mesh refinement - how to define mass flow BCs? shockley OpenFOAM 1 December 13, 2010 05:04
Customized User Field Function - Vector hannow STAR-CCM+ 1 December 10, 2009 08:25
Customized solver to run in parallel hsieh OpenFOAM Running, Solving & CFD 3 September 21, 2006 05:59
