OpenFOAM: Adding a transient pressure gradient to a solver |
January 28, 2016, 17:24 |
Rep Power: 14 |
I am trying to add a pressure gradient, that changes with time, to a solver. I have a sinusoidal pressure gradient working, but I am having trouble ramping up the frequency. I'm new to OpenFOAM and C++, and it's pretty clear I am not calling functions properly, but I don't know how to resolve.
As a test, I want to apply the sinusoidal gradient until time = 5, then have the gradient go to zero for the remainder of the simulation. If I can get this working, I should be able to set up the actual ramping I want. I'm mostly interested in calling the ceiling, floor, and minimum functions properly. And, I know the arguments for the minimum function are not of the same type, but don't know how to get them to match. Thanks for any insight, Dan In UEqn.H: tmp<fvVectorMatrix> UEqn ( fvm::ddt(U) + fvm::div(phi, U) + turbulence->divDevReff(U) == fvOptions(U) +dpdx*cos(Freq*runTime.time().value()) *ceil((t0-std::min(runTime.time().value(),t0))/t0) ); In createFields.H: dimensionedScalar t0 ( transportProperties.lookup("t0") ); In transportProperties: t0 t0 [ 0 0 1 0 0 0 0 ] 5 ; When I compile the solver, I get the following errors: ./UEqn.H:11:12: error: no matching function for call to 'min' *ceil((t0-std::min(runTime.time().value(),t0))/t0) ^~~~~~~~ /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/algorithm:2589:1: note: candidate template ignored: deduced conflicting types for parameter '_Tp' ('double' vs. 'Foam::dimensioned<double>') min(const _Tp& __a, const _Tp& __b) ^ /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/algorithm:2599:1: note: candidate template ignored: could not match 'initializer_list<type-parameter-0-0>' against 'double' min(initializer_list<_Tp> __t, _Compare __comp) ^ /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/algorithm:2581:1: note: candidate function template not viable: requires 3 arguments, but 2 were provided min(const _Tp& __a, const _Tp& __b, _Compare __comp) ^ /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/algorithm:2607:1: note: candidate function template not viable: requires single argument '__t', but 2 arguments were provided min(initializer_list<_Tp> __t) ^ 1 error generated. make: *** [Make/darwinIntel64ClangDPOpt/pimpleFoamPulsTempRamp.o] Error 1 |
January 29, 2016, 00:29 |
Darrin Stephens
Rep Power: 17 |
Hi Dan,
Your compilation problem is caused by t0 being a dimensionsedScalar. Try using t0.value() in the min function. |
January 29, 2016, 10:32 |
Rep Power: 14 |
Darrin,
Thank you for the response. I should have mentioned that I tried using t0.value() but it produced a much longer list of errors. But the first error was again a mismatched-arguments-for-min-function error: In file included from pimpleFoamPulsTempRamp.C:77: ./UEqn.H:11:2: error: invalid operands to binary expression ('Foam::dimensioned<typename Foam::outerProduct<Vector<double>, double>::type>' and 'double') *std::min(runTime.time().value(),t0.value()) ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /Users/dshagan/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude/dimensionedScalar.H:55:19: note: candidate function not viable: no known conversion from 'dimensioned<typename Foam::outerProduct<Vector<double>, double>::type>' to 'const dimensioned<scalar>' for 1st argument dimensionedScalar operator*(const dimensionedScalar&, const scalar); So, I simplified my UEqn to focus on the min function: tmp<fvVectorMatrix> UEqn ( fvm::ddt(U) + fvm::div(phi, U) + turbulence->divDevReff(U) == fvOptions(U) +dpdx*cos(Freq*runTime.time().value()) *std::min(runTime.time().value(),t0.value()) // *ceil((t0-min(runTime.time().value(),t0.value()))/t0) ); But again the arguments for the min function are "invalid operands". I have attached the compilation log. How can I make the two following types of operands compatible? 'Foam::dimensioned<typename Foam::outerProduct<Vector<double>, double>::type>' and 'double' And am I calling the min function properly by using "std::min"? Any input is much appreciated. Thanks again, Dan |
January 29, 2016, 18:08 |
David Gaden
Rep Power: 22 |
The compiler is complaining that something is a type:
Foam::dimensioned<typename Foam::outerProduct<Vector<double>, double>::type> Oh, it isn't complaining about std::min, it's complaining about your multiplication before that. What's dpdx?
~~~ Follow me on twitter @DavidGaden |
January 29, 2016, 19:54 |
Rep Power: 14 |
marupio,
Thanks for the response. The 'dpdx' term is a unit vector which defines the direction of the pressure gradient. I have the following code. In createFields.H: // Pressure gradient direction dimensionedVector dpdx ( transportProperties.lookup("dpdx") ); // Frequency of sinusoidal pressure gradient dimensionedScalar Freq ( transportProperties.lookup("Freq") ); // Time at which Freq is ramped up dimensionedScalar t0 ( transportProperties.lookup("t0") ); In transportProperties: //define the pressure gradient value dpdx dpdx [ 0 1 -2 0 0 0 0 ] ( 1 0 0 ); // Freq = 2pi/Period // Period=30: Freq = 0.20943951 Freq Freq [ 0 0 0 0 0 0 0 ] 0.20943951; //ramp up frequency times t0 t0 [ 0 0 1 0 0 0 0 ] 5 ; I also noticed that my "simplified" pressure gradient term, in Post #3, unbalances the units of the righthand side of the UEqn. But it doesn't sound like that is the problem here. Thanks! Dan Last edited by dsh5400; January 30, 2016 at 11:24. |
January 31, 2016, 16:50 |
Darrin Stephens
Rep Power: 17 |
Hi Dan,
Change you code as follows In UEqn.H scalar minValue(min(runTime.time().value(),t0.value())); dimensionedScalar factor(minValue*cos(Freq*runTime.time().value())); tmp<fvVectorMatrix> UEqn ( fvm::ddt(U) + fvm::div(phi, U) + turbulence->divDevReff(U) == fvOptions(U) + factor*dpdx ); I believe it was the order of the multiplication that the compiler didn't like. |
February 4, 2016, 09:32 |
Rep Power: 14 |
Thank you darrin!
This gives me what I need. I will post my final code once I get everything working as it should. Thank you! Dan |
April 7, 2016, 16:13 |
Rep Power: 14 |
I was able generate a transient pressure gradient of the form:
Pgrad.pdf The pressure gradient is sinusoidal with a a constant period of 60 until time t0, a linearly increasing period from 60 to 30 at time tF, then a constant period of 30 after time tF. In the attached figure, t0=60 and tF=180. To do this in OpenFOAM, I modified the UEqn.H file: Code:
// Solve the Momentum equation // // First constant frequency value scalar firstMinValue(min(runTime.time().value(),t0.value())); scalar firstBinMin(ceil((t0.value()-firstMinValue)/t0.value())); dimensionedScalar firstFactor(firstBinMin*cos(firstFreq*runTime.time().value())); // Second constant frequency value scalar secondMaxValue(max(runTime.time().value(),tF.value())); scalar secondBinMax(ceil((secondMaxValue-tF.value())/tEnd.value())); dimensionedScalar secondFactor(-secondBinMax*cos(secondFreq*runTime.time().value())); // Intermediate ramping frequency value(s) scalar rampTime((runTime.time().value()-t0.value())/(tF.value()-t0.value())); dimensionedScalar rampFreqDiff(0.5*(secondFreq-firstFreq)); // dimensionedScalar rampFreq(firstFreq+rampTime*rampFreqDiff); scalar rampMaxValue(max(runTime.time().value(),t0.value())); scalar rampMinValue(min(runTime.time().value(),tF.value())); scalar rampBinFactor(floor(0.5*(ceil((rampMaxValue-t0.value())/tEnd.value()) +ceil((tF.value()-rampMinValue)/tEnd.value())))); dimensionedScalar rampFactor(rampBinFactor*cos(rampFreq*runTime.time().value())); // Exact frequency value at t0 scalar firstAbsTime(std::abs(runTime.time().value()-t0.value())); scalar firstExactVal(1.0-ceil(firstAbsTime/tEnd.value())); dimensionedScalar firstExactFactor(firstExactVal*cos(firstFreq*runTime.time().value())); // Exact frequency value at tF scalar secondAbsTime(std::abs(runTime.time().value()-tF.value())); scalar secondExactVal(1.0-ceil(secondAbsTime/tEnd.value())); dimensionedScalar secondExactFactor(-secondExactVal*cos(secondFreq*runTime.time().value())); tmp<fvVectorMatrix> UEqn ( fvm::ddt(U) + fvm::div(phi, U) + turbulence->divDevReff(U) == fvOptions(U) + firstFactor*dpdx + secondFactor*dpdx + rampFactor*dpdx + firstExactFactor*dpdx + secondExactFactor*dpdx ); UEqn().relax(); fvOptions.constrain(UEqn()); volScalarField rAU(1.0/UEqn().A()); if (pimple.momentumPredictor()) { solve(UEqn() == -fvc::grad(p)); fvOptions.correct(U); } Code:
//define the pressure gradient value dpdx dpdx [ 0 1 -2 0 0 0 0 ] ( 1 0 0 ); // Freq = 2pi/Period // Period=30: Freq = 0.20943951 // Period=40: Freq = 0.15707963 // Period=60: Freq = 0.104719755 firstFreq firstFreq [ 0 0 0 0 0 0 0 ] 0.104719755; secondFreq secondFreq [ 0 0 0 0 0 0 0 ] 0.20943951; //ramp up frequency times (removed units!!) t0 t0 [ 0 0 0 0 0 0 0 ] 60; //1 ; //300 ; tF tF [ 0 0 0 0 0 0 0 ] 180; //600; //30 ; //400 ; tEnd tEnd [ 0 0 0 0 0 0 0 ] 900 ; |
Rotating Reference Frame Pressure Gradient | clac | FLUENT | 0 | August 22, 2012 19:20 |
Rotating wall: Pressure BC in OpenFoam using rhoCentralFoam solver | vinaykr | OpenFOAM | 0 | June 27, 2011 05:11 |
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver | renyun0511 | OpenFOAM Running, Solving & CFD | 0 | November 10, 2010 02:47 |
Conjugate gradient solver for pressure. | R.F. | Main CFD Forum | 0 | November 12, 2004 12:49 |
pressure gradient term in low speed flow | Atit Koonsrisuk | Main CFD Forum | 2 | January 10, 2002 11:52 |
