Drived Boundary Conditions
Old   January 25, 2016, 10:59
Red face Drived Boundary Conditions
Mohsen
mohsen.boojari is on a distinguished road
hi,
i tried to drive a new boundary condition in heat transfer module, at the end when i tried to run wmake command , the error below showed up. can anyone help me?
thank You
convectiveHeatFluxFvPatchScalarField.C:109:64: error: invalid initialization of reference of type ‘const Foam::fvsPatchField<double>&’ from expression of type ‘const PatchFieldType {aka const Foam::fvPatchField<double>}’
patch().lookupPatchField<volScalarField, scalar>(TName_);
and this is my convectiveHeatFluxFvPatchScalarField.C file . i've attached it.
the error says problem is in line 109 !
mohsen.boojari is offline   Reply With Quote
Old   January 27, 2016, 12:42
David Gaden
marupio is on a distinguished road
Line 109 is:
    const fvsPatchField<scalar>& T =
I am the class you are trying to create. I am an fvPatchField. When you call patch(), I will give you my fvPatch. If you use my fvPatch to call lookupPatchField, it will return an fvPatchField. You are telling me that you want an fvsPatchField? With an 's' after the fv? That's a surface field, and is a totally different data structure. Us fvPatchFields don't play nice with fvsPatchFields. There are some functions that allow us to talk together, but they use interpolation, which introduces instabilities.
What is T supposed to be? Maybe try changing it to an fvPatchField.
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   January 27, 2016, 13:04
Mohsen
yeah David. you are right. there was an addition 's' in the code .
T represent the temperature field .
boundary condition, convection, temperature
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 10:49
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
