Impose Pressure to cellSet
Old   January 18, 2016, 11:45
Default Impose Pressure to cellSet
hxaxtma is on a distinguished road
Hi guys,
I am trying to impose a pressure value to a selected cellSet.
This is what I have done so far after cellSet creation shown by a Snippet!:
        Info << "Loop through cellSet: " << runTime.timeName() << endl;
        const labelList& cells = sensorCells.toc();
        forAll(cells,I)
            Info << cells[I] << endl;
            p[cells[I]]=10;
            Info << "Add pressure " <<  endl;
Code is compiling, but no pressure jump appears. Where is the problem?
Solver compiles, but no pressure
Last edited by hxaxtma; January 18, 2016 at 11:46. Reason: And 2nd question, how can I access the x,y,z component values of the cells in the for loop?
hxaxtma is offline   Reply With Quote
Old   January 18, 2016, 11:53
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
1. Concerning your implementation: when do you update values?
2. There is Foam::fv::explicitSetValue fvOption. You can find usage suggestions in $FOAM_SRC/fvOptions/constraints/general/explicitSetValue/ExplicitSetValue.H.
3. Cell centers are kept in fvMesh::C() vector field (http://foam.sourceforge.net/docs/cpp...144592e78ccdba).
alexeym is offline   Reply With Quote
Old   January 18, 2016, 13:20
Originally Posted by alexeym View Post
Thanks for your advice:
1. Added in the main loop for every timestep (cellSet changes every timestep)
2.Hm, I am a bit confused about the ExplicitSetValue.H/C code? Which part exactly would help me out here?
Old   January 18, 2016, 14:54
Alexey Matveichev
1. Could you post your "main loop"?
2. One, which explicitly sets value of a given field. Though, since you have said that cellSet changes every time step, fvOption framework is not really an option.
Old   January 19, 2016, 06:41
Hi Alex,
here is my mainloop, I commented the fluid solving out:
#include "fvCFD.H"
#include "sensorArray.H"
// Main program:
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    #include "createFields.H"
    #include "initContinuityErrs.H"
    // Pre-process the cell set for the first time-step.
    selectSensor(sensorCells, mesh);
    sensorCells.write();
    Info<< "\nStarting time loop\n" << endl;
    while(runTime.loop())
        //icoFoam START
         #include "readPISOControls.H"
        #include "CourantNo.H"
        fvVectorMatrix UEqn
            fvm::ddt(U)
          + fvm::div(phi, U)
          - fvm::laplacian(nu, U)
        solve(UEqn == -fvc::grad(p));
        // --- PISO loop
        for (int corr=0; corr<nCorr; corr++)
            volScalarField rAU(1.0/UEqn.A());
            volVectorField HbyA("HbyA", U);
            HbyA = rAU*UEqn.H();
            surfaceScalarField phiHbyA
                "phiHbyA",
                (fvc::interpolate(HbyA) & mesh.Sf())
              + fvc::interpolate(rAU)*fvc::ddtCorr(U, phi)
            adjustPhi(phiHbyA, U, p);
            for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
                fvScalarMatrix pEqn
                    fvm::laplacian(rAU, p) == fvc::div(phiHbyA)
                pEqn.setReference(pRefCell, pRefValue);
                pEqn.solve();
                if (nonOrth == nNonOrthCorr)
                    phi = phiHbyA - pEqn.flux();
            #include "continuityErrs.H"
            U = HbyA - rAU*fvc::grad(p);
            U.correctBoundaryConditions();
            //End PISO Loop
        //END icoFOAM
        //Info << "Time: " << runTime.timeName() << endl;
        //Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s";
        //Info << "ClockTime = " << runTime.elapsedClockTime() << " s";
        Info << "Create Sensor Cell Set Time: " << runTime.timeName() << endl;
        Info << "Calculate Volume Force: " << runTime.timeName() << endl;
        vector u_bf;                       // Velocity BaseFlow
        const labelList& sensorCell = sensorCells.toc();
        forAll(sensorCell,i)
            //Info << cells[I] << endl;
            u_bf=U[sensorCell[i]]; // Get Baseflow Velocity over CellSet
            //const volVectorField& C_sensor = mesh.C().sensorCell[i];
            //volScalarField Cx_sensor = C_sensor.component(0);
            //volScalarField Cy_sensor = C_sensor.component(1);
            //volScalarField Cz_sensor = C_sensor.component(2);
            Info << "Get Velocity of Baseflow of SensorSet " << sensorCells[i] << ": "<< u_bf << endl;
            //p[cells[I]]+=10;
    Info<< "\nEnd\n" << endl;
    return 0;
In #include "sensorArray.H" I just set my cellSet Zone by geometrical contraints.
Next I want to loop over the cellSet and impose a volume force in dependence of y.Position of the cells.
Thanks for help
Old   January 19, 2016, 12:27
Alexey Matveichev
Maybe I am missing something but...
1. I do not see call to runTime.write().
2. Code changing pressure is commented out.
Old   January 19, 2016, 12:29
Hehe, yes it is commented out, cause this is not working.
and I just forgot to post runtime.write() in the Code Snippet above.
Anyway, this should only represent the main "idea".
Old   January 19, 2016, 12:34
Alexey Matveichev
Well... your "idea" is "in principle" correct. BUT you do not execute "idea", you execute your "code", and the error is in your REAL "code". Good luck with "idea".
Old   January 20, 2016, 04:37
Hi Alex,
I am sorry if I insulted you in a way. I did not want to. I just wanted to point out that I am only missing the function to write field values in the selected cells of the cellSet and the commented line //p[..]+=10 is not working here for me properly.
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 13:23
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
Outlet pressure aja1345 FLUENT 5 August 18, 2015 12:02
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
