Solve double laplacian (laplacian of laplacian) equation
Old   January 5, 2016, 22:07
Default Solve double laplacian (laplacian of laplacian) equation
Thomas Oliveira
t.oliveira is on a distinguished road
I can successfully solve \nabla^2 p =0 using
solve(fvm::laplacian(p));
How can I solve \nabla^4 u =0?
Besides that, would mixed boundary conditions for u be enough?
Thanks!
t.oliveira is offline   Reply With Quote
Old   January 13, 2016, 16:17
Bruno Blais
blais.bruno is on a distinguished road
You can solve by carrying out a double laplacian with a mute variable
mute= solve(fvm::laplacian(p));
solve(fvm::laplacian(mute));
And then solve iteratively until convergence. For periodic boundary conditions, this preserves second order (or whatever order your scheme is)
The solution contained in mute will be the solution to
\nabla^4 u =0?
The problem is that this requires boundary condition for both p and mute, thus you need to have 2 boundary conditions for mute, which is not generally the case if you are trying to solve \nabla^4 u =0.
However, solving a fourth degree equation straight away with openfoam is not possible as far as I know.
Originally Posted by t.oliveira View Post
Thanks!
blais.bruno is offline   Reply With Quote
Old   February 1, 2016, 10:49
Thomas Oliveira
Thanks, Bruno. This answers my questions.
Help with if statement CHARLES OpenFOAM Programming & Development 17 August 22, 2021 04:14
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
Parallel User Defined Real Gas Model aeroman FLUENT 4 July 1, 2015 07:09
solve an implicit equation in UDF Rui_27 Fluent UDF and Scheme Programming 0 September 8, 2014 11:12
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
