Implementing surface force in interFoam
Old   December 11, 2015, 08:29
Default Implementing surface force in interFoam
Maximilian Transinger
traens is on a distinguished road
Is there a possibility to "mimic" a moving mesh in interFoam?
I am conducting simulations on sloshing, and for the post processing I would prefer a static mesh.
At first I thought of applying a body force, but this approach is apparently wrong, since I have a free surface. Now, I thought of implementing something like a surface force / or a body force which only applies to the cells layer directly at the wall. Thus, I thought it could be possible apply a force, which in the end produces the same result on the fluid like a moving mesh.
Does anyone have experience with that, or tried out this approach?
Thanks!
traens is offline   Reply With Quote
Old   December 11, 2015, 13:17
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
I was under the impression that the body force model is the most common approach for multiphase sloshing simulations. Why do you think it wouldn't work?
kmooney is offline   Reply With Quote
Old   July 17, 2017, 05:14
sai murali
saimurali is on a distinguished road
have you figured it out on how to apply the body forces in interFoam
saimurali is offline   Reply With Quote
interfoam, moving mesh, sloshing, surface force
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
Plotting Surface tension force with interfoam Mahmoud_aboukhedr OpenFOAM Programming & Development 5 December 1, 2016 09:37
impact force (shear stress) by waterjet impingement herozhu Main CFD Forum 0 May 7, 2014 21:39
Implementing a dynamic retention force in interFoam u2947 OpenFOAM Programming & Development 2 June 17, 2013 10:14
Tensions on free surface interFoam sega OpenFOAM Running, Solving & CFD 0 April 29, 2008 15:26
