fieldAverage fails to continue averaging the fields
Old   December 7, 2015, 17:10
Thumbs down fieldAverage fails to continue averaging the fields
Fernando Soares Alves
FernandoSoares is on a distinguished road
Hi there dear Foamers,
I am currently running some simple LES cases and I wish to, during runTime, average some fields of interest. For instance I'm using fieldAverage in my controlDict in the following way
funtions
    fieldAverage
        type                    fieldAverage;
        functionObjectLibs      ("libfieldFunctionObjects.so");
        enabled                 true;
        cleanRestart            false;
        outputControl           outputTime;
        resetOnOutput           false;
        resetOnRestart          false;
        fields
            U
                mean        on;
                prime2Mean  on;
                base        time;
            p
               mean         on;
               prime2Mean   off;
               base         time;
Right now I face multiple 'sudden-stops' here at the University and every time I restart the simulation from its latestTime the averages, specially UPrime2Mean, start all over again. How could I avoid such an issue? Am I setting the controlDict (functions) incorrectly?
Could any expert or someone who has already experienced a similar situation advise me?
Thanks in advance and best regards,
F. Soares.
FernandoSoares is offline   Reply With Quote
Old   December 8, 2015, 05:12
Retired Super Moderator
Bruno Santos
Quick answer: I vaguely remember there was a bug related to this in one of OpenFOAM's older versions. I've found the bug report for it: http://www.openfoam.org/mantisbt/view.php?id=898
Which version of OpenFOAM are you using?
Old   December 8, 2015, 08:48
Sorry, I should have attached the other threads I was reading about this issue. I currently use OpenFOAM 2.4.x.
Old   December 8, 2015, 08:56
Bruno Santos
A few quick questions:
  1. Does your "controlDict" really have then entry named "funtions", or did you only mistype here on the post? Notice that it's missing a "c".
  2. Do you know which is the latest commit of 2.4.x you have? You can check with the following command:
    blockMesh -help
    the hash number is shown near the end, associated to the version number.
  3. Can you provide a quick test case with which this issue can be reproduced? For example, can you reproduce this with one of the tutorial cases from OpenFOAM?
Old   December 8, 2015, 13:30
According to 'blockMesh -help' I am currently
Using: OpenFOAM-2.4.x (see www.OpenFOAM.org)
Build: 2.4.x-e713234c04f6
Sorry about that, typo common mistake. My controlDict file is
|  \\    /   O peration     | Version:  2.4.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     pisoFoam;
startFrom       startTime;
startTime       200;
stopAt          endTime;
endTime         3000;
deltaT          2e-04;
writeControl    adjustableRunTime;
writeInterval   0.25;
purgeWrite      1;
writeFormat     ascii;
writePrecision  6;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  on;
maxCo           0.250000;
maxDeltaT       0.001500;
functions
    fieldAverage1
        type                fieldAverage;
        enabled             true;
        cleanRestart        false;
        fields
            U
                mean        on;
                prime2Mean  on;
                base        time;
            p
               mean        on;
               prime2Mean   off;
               base         time;
    epsilon
       type              epsilonTsr;
        UName           U;
        UMeanName       UMean;
        functionObjectLibs ("myTurbFieldsFunctionObjects.so");
        enabled         true;
    epsilonTrue
        type              epsilonTsrTrue;
        UName           U;
        UMeanName       UMean;
        enabled         true;
    pStrain
        type              pStrain;
        UName           U;
        UMeanName       UMean;
        pName            p;
        pMeanName        pMean;
        enabled         true;
    pU
        type            pU;
        UName           U;
        UMeanName       UMean;
        pName            p;
        pMeanName        pMean;
        enabled         true;
    triU
        type             triU;
        UName           U;
        UMeanName       UMean;
        enabled         true;
    fieldAverage2
        type                fieldAverage;
        enabled                 true;
        cleanRestart            false;
        fields
        epsilonTsr
        mean        on;
        prime2Mean  off;
        base        time;
        epsilonTsrTrue
        mean        on;
        prime2Mean  off;
        base        time;
        pStrain
        mean        on;
        prime2Mean  off;
        base        time;
        pU
        mean        on;
        prime2Mean  off;
        base        time;
        triU
        mean        on;
        prime2Mean  off;
        base        time;
    probes
        type            probes;
        functionObjectLibs ("libsampling.so");
        enabled         true;
        outputControl   timeStep;
        outputInterval  10;
        fields
        // inst fields
        U
        p
        k
        // mean fields
        UMean
            pMean
        UPrime2Mean
        epsilonTsrMean
        epsilonTsrTrueMean
        pStrainMean
        pUMean
        triUMean
        probeLocations
        (0.125 0.95 0)
        (0.250 0.95 0)
        (0.375 0.95 0)
        (0.500 0.95 0)
        (0.625 0.95 0)
        (0.750 0.95 0)
        (0.875 0.95 0)
        (0.125 0.85 0)
        (0.250 0.85 0)
        (0.375 0.85 0)
        (0.500 0.85 0)
        (0.625 0.85 0)
        (0.750 0.85 0)
        (0.875 0.85 0)
        (0.125 0.7 0)
        (0.250 0.7 0)
        (0.375 0.7 0)
        (0.500 0.7 0)
        (0.625 0.7 0)
        (0.750 0.7 0)
        (0.875 0.7 0)
        (0.125 0.6 0)
        (0.250 0.6 0)
        (0.375 0.6 0)
        (0.500 0.6 0)
        (0.625 0.6 0)
        (0.750 0.6 0)
        (0.875 0.6 0)
The other fields I am trying to take averages are related to the transport of the Reynolds stress. So I'm in fact doing two averages in my simulation: fieldAverage1 and fieldAverage2.
Once again thank you for your time and patience Mr. Santos,
F. Soares.
Old   December 8, 2015, 14:39
I forgot to address a similar tutorial in my last reply. In $FOAM_TUTORIALS/incompressible/pisoFoam/les/pitzDaily there is a similar structure to the case I am trying to run here. However modifying the controlFidct file
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
//startFrom       startTime;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
//endTime         10e-05;
endTime         20e-05;
deltaT          1e-05;
writeControl    timeStep;
writeInterval   1;
purgeWrite      1;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions
    fieldAverage1
        type            fieldAverage;
        enabled         true;
        timeStart       3e-05;
        fields
            U
                mean        on;
                prime2Mean  off;
                base        time;
            p
                mean        on;
                prime2Mean  off;
                base        time;
    fieldAverage2
        type            fieldAverage;
        enabled         true;
        timeStart       9e-05;
        fields
            U
                mean        on;
                prime2Mean  on;                base        time;
so to use fieldAverage twice (one for obtaining p and U mean field and another for UPrime2Mean) doesn't seem to yield the problem I've been having all this time. According to the log after restarting the simulation under the programmed stop
Starting time loop
fieldAverage fieldAverage1:
    Restarting averaging for fields:
        U iters = 5 time = 5e-05
fieldAverage fieldAverage2:
Apparently OF is working for this specific tutorial. Any ideas why?
Old   December 8, 2015, 16:43
Bruno Santos
Hi F. Soares,
This is starting to look like it's a somewhat severe bug. The case you prepared with the tutorial has the function objects prepared differently and that could be enough for the first one to not conflict with the second one, given that you gave two different start times and different averaging mechanisms.
And I went looking for bug reports about "fieldAverage" and found the following issue still open: http://www.openfoam.org/mantisbt/view.php?id=1336 - it seems to be related to your issue.
I'm adding this to my to-do list for the upcoming weekend. If you can figure out a way to reproduce this issue with the tutorial case, it would help a lot in isolating the origin of the problem and to fix it.
The other possibility for the origin of this bug is if you are running in parallel at the University, which could potentially also bring up other problems.
Best regards,
Bruno
Starting field averaging using libFunctionObject after certain time eelcovv OpenFOAM Programming & Development 25 December 7, 2015 23:28
How to restart averaging of the fields? huangxianbei OpenFOAM Running, Solving & CFD 0 March 21, 2014 06:21
a reconstructPar issue immortality OpenFOAM Post-Processing 8 June 16, 2013 12:25
an odd(at least for me!) reconstructPar error on a field immortality OpenFOAM Running, Solving & CFD 3 June 3, 2013 23:36
EULER-Forward-Method freak Main CFD Forum 4 June 12, 2001 10:19
