Has any one tried AmgX on OpenFOAM
Like Tree5Likes
Old   January 23, 2023, 04:44
Klaus
klausb will become famous soon enough
I found out, that the AmgX-OpenFOAM integration has been done in another way using a new interface called FOAM2CSR instead of the wrapper.
So it's:
OpenFOAM > PETSc4FOAM > FOAM2CSR > AmgX
See youtube: SU2 Conference 21: An Implementation of AmgX for GPU Acceleration of OpenFOAM
https://www.youtube.com/watch?v=1d1DVURNz4E
FOAM2CSR
https://gitlab.hpc.cineca.it/openfoam/foam2csr
klausb is offline   Reply With Quote
Old   January 24, 2023, 03:33
Nitish25 is on a distinguished road
Originally Posted by dlahaye View Post
Let us talk very briefly now and find a slot to talk more extensively next week.
Please send me link for Google meet either here or on private cfdonline address.
Dhanyavaad.
Respected Sir,
As per the last conversation you told that to schedule meeting at 24 jan for detailed information
PF Link
https://meet.google.com/ujq-qheo-sdz
Thank you for your valuable time and efforts
Thanks & regards
dlahaye likes this.
Nitish25 is offline   Reply With Quote
Old   January 24, 2023, 04:17
Dhanyavaad.
Respected Sir,
PF Link
Thanks & regards
Old   January 24, 2023, 05:13
Originally Posted by Nitish25 View Post
Respected Sir,
PF Link
Thanks & regards
sir if u are free, plz join the meeting now, I'm eagerly waiting for u.
Old   January 24, 2023, 05:32
Domenico Lahaye
dlahaye is on a distinguished road
We scheduled our meeting for 16:00 this afternoon, i.e., 5.5 hours from now.
What is progress on compiling and linking AMGX tutorial, independently from OpenFoam?
dlahaye is offline   Reply With Quote
Old   January 24, 2023, 05:51
Domenico Lahaye
So it's:
FOAM2CSR
Dear Klaus,
1/ I imagine that FOAM2CSR applies to the OpenFoam LDU matrix format. FOAM2CSR does *not* apply to the PETSc matrix format. Can you confirm?
2/ Does AMGX apply to an decomposed case, or does AMGX enforce its own parallel decomposition?
3/ When using AMGX to an incompressible case (like motorBike), AMGX is to be applied to the pressure field only?
Thanks. Domenico.
Old   January 24, 2023, 06:07
we have successfully build the amgx by following the steps as mention in their website https://github.com/NVIDIA/AMGX i.e. as shown below
mkdir build
cd build
cmake ../
make -j16 all
while, build it automatically compiles all the amgx example and generates their executable in the build directory.
we are able to run the amgx_capi (it is an executable file of AMGX/examples/amgx_capi.c )example on gpu inside the build directory by following command
examples/amgx_capi -m ../examples/matrix.mtx -c ../src/configs/FGMRES_AGGREGATION.json
so manually compilation of amgx/examples is not required.
Thank you for ur valuable time.
Old   January 24, 2023, 09:16
Domenico Lahaye
Yes and no.
Yes, I understand that the manually building the examples of AMGX/examples is *not* required.
No, however, I am not interested in building the examples of AMGX/examples as a final goal. Building the examples of AMGX/examples is intended as a seperate step to *understand* the compile and build process of AMGX/examples.
There are now two ways to proceed
1/ First alternative
Repeat the entire build process, and replace in the last step "make -j16 all" by "make -j16 all >& log.makeAMGX" in such a way that the output of the make process is written to the log-file log.makeAMGX that we can inspect. A search on amgx_capi.c should provide the information we are after.
2/ Second alternative
Assume that all the header files are included in AMGX/include and its subdirectory and that all the library files (files with extension *.a or *.so) are
in some lib directory.
We can proceed with a copy-and-paste of the source of amgx_capi.c into myLaplacianFoam and try to compile, link and run it.
Let me know how it goes.
Old   January 25, 2023, 04:34
Yes and no.
hello sir
I have repeated the entire built process of AMGX and save in log file .
I hv attached the log file.
I am able to find build of amgx_capi.c at
[ 95%] Building C object examples/CMakeFiles/amgx_capi.dir/amgx_capi.c.o
in log file.
kindly reply next step.
Old   January 25, 2023, 05:00
Domenico Lahaye
We are making a small step in the good direction.
The log file, however, fails to give sufficient information. We need more information.
1/ Compile stage
Here is what we now know
Line 242 in log file
To obtain more information, the compiler (i.e. gcc -c) needs to output more information.
2/ Link stage
Line 247 in log file:
[ 97%] Linking C executable amgx_capi
To obtain more information, the linker (i.e. gcc -L ) needs to output more information.
3/ Next Step
To obtain the required additional information, can you please type
cd examples/CMakeFiles/amgx_capi.dir
and subsequently type
make
Dhanyavaad.
Old   January 25, 2023, 05:16
1/ Compile stage
2/ Link stage
3/ Next Step
make
Dhanyavaad.
sir
we have entered the examples/CMakeFiles/amgx_capi.dir
and have typed make
but it says
make: *** No targets specified and no makefile found. Stop.
kindly reply
Old   January 25, 2023, 05:42
Domenico Lahaye
I am confused.
The file "makefile" (or variant) seems to be missing.
What is the output of
cd <AMGX-main-directory>
find . -name *makefile* -print
Old   January 25, 2023, 05:51
I am confused.
after type
in main amgx directory,
it print:
./examples/install_makefiles_mpi
./examples/install_makefiles_nompi
when I type
find . -name *Makefile* -print
it prints:
./build/CMakeFiles/Makefile.cmake
./build/CMakeFiles/Makefile2
./build/examples/Makefile
./build/thrust/Makefile
./build/Makefile
./build/src/Makefile
./examples/Makefile.cray
./examples/amgx_spmv_example/Makefile
./examples/install_makefiles_mpi/Makefile
./examples/install_makefiles_nompi/Makefile
./thrust/Makefile
Old   January 25, 2023, 07:04
after type
it print:
when I type
it prints:
./build/Makefile
./thrust/Makefile
plz find the attached image
Old   January 25, 2023, 08:38
Domenico Lahaye
1/ What is the output of the following:
cd examples
ls
make -f Makefile.cray amgx_capi
2/ I send you a link to join a slack group
Talk soon. D.
Old   February 2, 2023, 17:40
Klaus
Dear Domenico,
regarding your questions:
See timestamp 2:46 in the youtube video. It explains the role of FOAM2CSR, it handles "the GPU co-ordination, matrix consolidation, data transfers, transformations and dispatching linear systems to AmgX." I haven't looked into the source code of FOAM2CSR to see what's its relationship with PETSc4FOAM. In the video, they talk about converting the LDU format to the CSR format used by AmgX, I assume because it's computationally cheaper to do the conversion.
That's a misunderstanding I'd say. AmgX is the solver library, FOAM2CSR handles the "consolidation" of decomposed cases according to the number of available GPUs if the number of CPU cores and available GPUs differ.
No, it's not limited to the pressure field.
Klaus
Old   February 9, 2023, 03:45
Dcn
Dcn is on a distinguished road
So it's:
FOAM2CSR
Sir i have compile and build the foam2CSR and have got libfoam2csr.so and have also build PETSc4FOAM and have got libpetscfoam.so , similarly i have successfully build the Amgx library , now can you kindly tell me how to use FOAM2CSR with Amgx
Thank you
Dcn is offline   Reply With Quote
Old   February 10, 2023, 16:12
Domenico Lahaye
Dear Klaus,
Thank you for your reply. Much appreciated!
Re-1: Thank you for pointing out the link to the video.
Re-2: I fail to understand what the purpose of FOAM2CSR is. Once in PETSc, the matrix is in a format that PETSc understands. Clearly, I am missing something.
Re-3: I agreed that GAMG can solve velocity components. I wonder, however, whether the use of GAMG for the velocity components offers any gains.
Thanks again. Talk soon, Domenico.
Old   February 10, 2023, 16:26
Domenico Lahaye
Dear Dcn,
I fail to understand what the purpose of FOAM2CSR is. Clearly and most obviously, I am missing the point.
I therefore developed myLaplacianFoam at placed it at https://github.com/ziolai/software/t...yLaplacianFoam. This code convert the LDU matrix format to CSR format using code available from https://gist.github.com/BinWang0213/...b8e25ac014cc48.
In a next step I wish to extend myLaplacianFoam with something like
// Call Initialize
AMGX_initialize();
AMGX_resources_create(&rsrc, cfg, &amgx_mpi_comm, 1, &lrank);
AMGX_matrix_create(&A, rsrc, mode);
AMGX_vector_create(&x, rsrc, mode);
AMGX_vector_create(&b, rsrc, mode);
AMGX_solver_create(&solver, rsrc, mode, cfg);
// Call AMGX set-up stage
AMGX_solver_setup(solver, A);
// Call AMGX solve stage
AMGX_solver_solve(solver, b, x);
// Call Finalize
AMGX_finalize();
Does this make sense?
Old   May 16, 2024, 07:06
Walid Badawy is on a distinguished road
Hi Nitish, did you managed to do it with Klaus workflow!
Walid Badawy is offline   Reply With Quote
amgx, gpu, library, nvidia, openfoam 2.2.x
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
OpenFOAM Foundation releases OpenFOAMŪ 3.0.0 CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 1 November 7, 2015 16:16
OpenFOAM Foundation Releases OpenFOAM v2.3.0 opencfd OpenFOAM Announcements from OpenFOAM Foundation 3 December 23, 2014 04:43
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
