November 18, 2015, 22:25 |
WenYu drag model code implimentation
Thien Xuan Dinh
Rep Power: 12 |
Dear Foamer,
Taking a look to ErgunWenYu drag model for the lagrangian tracking, OF 2.3.0 with alphac > 0.8, I think something wrong there, where the factor (1 - alphac) disappears. Furthermore, can someone explain why alphac appears in the denominator? Best, |
November 25, 2015, 09:21 |
César Augusto Corrêa Miguéis
Rep Power: 12 |
dinh, I'm stucked in the very same question, did you have sucess about this thread? The Ergun part seems correct, but I agree with you that something looks bad in the Wen and Yu part.
César Miguéis Mechanical Engineer MSc. Student at COPPE/UFRJ |
April 8, 2016, 08:53 |
#3 | |
Li Linmin
Rep Power: 10 |
(mass/p.rho())*(150.0*(1.0 - alphac)+1.75*Re)*muc/(alphac*sqr(p.d())) because alphac is divided with (alphac*sqr(p.d())). does anyone find the same question? |
September 10, 2017, 21:42 |
QuocThien
Rep Power: 13 |
I believe that the formula should be:
(mass/p.rho())*(150.0*(1.0 - alphac)/alphac+1.75*Re)*muc/(sqr(p.d())) Because Sp = V*beta/(1.0 - alphac) where beta = F*18*(1.0 - alphac)*alphac*muc/sqr(q.d()) Then there is no /alphac in the end in Ergun approximation. When I run Single particle sedimentation in openfoam, the velocity of particle is smaller than the result by numerical analysis. |
August 2, 2023, 18:28 |
#5 | |
Shah Akib Sarwar
Rep Power: 5 |
May 23, 2024, 02:56 |
Josh Williams
Rep Power: 5 |
1-\alpha_c should not appear in the Lagrangian formulation of the model (only the two-fluid model version of the drag law).
If 1-\alpha_c is there, then the drag force will decay to 0 as the solid volume fraction approaches zero (e.g. a single small isolated sphere). However, it should not happen. The drag force should decay to stokes drag. I attached this figure showing drag force with varying \alpha_p and Re_p. Script to reproduce is below Code:
import numpy as np from numpy import pi import matplotlib.pyplot as plt def coeff_drag(Re): # if Re > 1000.0: # return 0.44*Re # else: return24.0*(1.0+0.15*Re**0.687) def dragmodel_current(alpha_p, Re, d_p=10e-6, rho_p=1207, muc=1.5e-5): alpha_c =1-alpha_p vol_p =4./3. * pi * (d_p/2)**3 return vol_p *0.75* coeff_drag(alpha_c*Re)*muc*pow(alpha_c, -2.65) / (alpha_c * np.square(d_p)) def dragmodel_literature(alpha_p, Re, d_p=10e-6, rho_p=1207, muc=1.5e-5): alpha_c =1-alpha_p vol_p =4./3. * pi * (d_p/2)**3 return vol_p *0.75* alpha_p * coeff_drag(alpha_c*Re)*muc*pow(alpha_c, -2.65) / (alpha_c * np.square(d_p)) def dragmodel_oneway(alpha_p, Re, d_p=10e-6, rho_p=1207, muc=1.5e-5): # alpha_p is unused num_vals = alpha_p.size alpha_p =None vol_p =4./3. * pi * (d_p/2)**3 return vol_p *0.75* coeff_drag(Re)*muc / np.square(d_p) * np.ones(num_vals) def stokes_drag(alpha_p, Re, d_p=10e-6, rho_p=1207, muc=1.5e-5): # alpha_p is unused num_vals = alpha_p.size alpha_p =None Re =None vol_p =4./3. * pi * (d_p/2)**3 # return vol_p * 0.75 * coeff_drag(Re)*muc / np.square(d_p) * np.ones(alpha_p.size) Cd =24 return vol_p *0.75* Cd * muc / np.square(d_p) * np.ones(num_vals) alpha_p = np.array([0] + (10**np.linspace(-4, -1, 6)).tolist() + np.linspace(0.1, 0.6, 10).tolist()) Re =10 # print(dragmodel_current(0.1, Re=10), dragmodel_literature(0.1, Re=10)) ls_list = ["-", "--", "dotted", "-."] fig, ax = plt.subplots() ax.scatter(alpha_p, stokes_drag(alpha_p, Re), label=f"Stokes drag", c="black") # plot drag force models at varying Reynolds numbers for i, Re inenumerate([0, 0.1, 100]): ax.plot(alpha_p, dragmodel_current(alpha_p, Re), label=f"Wen-Yu (OF), Re = {Re}", ls=ls_list[i], c="orange", lw=2) for i, Re inenumerate([0, 0.1, 100]): ax.plot(alpha_p, dragmodel_literature(alpha_p, Re), label=fr"Wen-Yu (with 1-$\alpha_f$), Re = {Re}", ls=ls_list[i], c="blue", lw=2) for i, Re inenumerate([0, 0.1, 100]): ax.plot(alpha_p, dragmodel_oneway(alpha_p, Re), label=f"Schiller-Nauman, Re = {Re}", ls=ls_list[i], c="green", lw=2) ax.set_yscale("log") ax.set_xscale("log") ax.set_ylabel(r"$\mathbf{f}_d$ [kg m / $s^2$]") ax.set_xlabel(r"$\alpha_p$ [-]") ax.set_title(r"Drag models at $d_p = 10^{-6} m$, $\rho_p = 1000$") # format plot for legend outside of plot box = ax.get_position() ax.set_position([box.x0, box.y0, box.width *0.6, box.height]) # tidy up for spine_i in ["top", "right"]: ax.spines[spine_i].set_visible(False) ax.legend(frameon=False,loc="center left", bbox_to_anchor=(1.,0.5)) plt.savefig("drag_forces.png", dpi=300) plt.show() |
Drag model implementation | vbchris | OpenFOAM Running, Solving & CFD | 1 | March 31, 2015 08:28 |
Applying drag force in the fluid model | CanadaFlanker | CFX | 7 | May 5, 2014 23:13 |
parallel code | samiam1000 | SU2 | 3 | March 25, 2013 04:55 |
multiphase flow modelling, Drag model | Anant | CFX | 1 | February 4, 2008 04:18 |
Use of an hydrodynamic model integrated in the vertical by the PHOENICS code | Hafsia Zouhaier | Main CFD Forum | 2 | March 15, 1999 08:23 |
