the global index for cells and facess in parallel computation
Like Tree34Likes
Old   November 2, 2015, 06:58
openfoammaofnepo is on a distinguished road
In the list of faceProcAddressing, I found that there are some negative indices in my case. Are they for the boundary faces or other particular types?
Also, the number of face in the file faceProcAddressing is the total number of faces in the local processor (physical boundary face, inter-processor faces and internal faces)? Thank you.
openfoammaofnepo is offline   Reply With Quote
Old   November 2, 2015, 10:31
The answer has been found:
For decomposed meshes there are additional files (labelIOLists) that refer back to the undecomposed mesh:
faceProcAddressing  for every face the original face in the undecomposed mesh. Also codes  whether the face has been reversed. If procFaceI is the local face index  and globalFaceI the index in the undecomposed mesh:
- faceProcAddressing[procFaceI] == 0 : not allowed
- faceProcAddressing[procFaceI] >0 : globalFaceI =  mag(faceProcAddressing[procFaceI])-1 and orientation same as  undecomposed mesh
- faceProcAddressing[procFaceI] <0 : globalFaceI =  mag(faceProcAddressing[procFaceI])-1 and orientation opposite to  undecomposed mesh.
So for face indices, it starts at 1, not 0. How about the cell indices? Start from 0 or from 1? Thanks.
Old   November 3, 2015, 04:30
The cell indices in the cellProcAddressing starts from 0, which is different from the faceProcAddressing (start from 0). Is this correct?
Old   November 7, 2015, 07:16
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
Just for those, who are still interested in how to write specified arrays at each MPI process to different files
    const word processFileName = "cellProcAddressing" +  Foam::name(Pstream::myProcNo());
    OFstream procFile (processFileName);
    procFile << cellProcAddressing << endl;
    procFile.flush() // to be sure that data flushed to disk
mkraposhin is offline   Reply With Quote
Old   November 17, 2015, 06:18
Dear Matvey,
Thank you so much. In the file of "faceProcAddressing", the faces included are both internal and boundary faces. But I am not sure their order in that file. I mean, internal face listed first, followed by the the indices for boundary faces?
Old   November 17, 2015, 07:21
mkraposhin's Avatar
Matvey Kraposhin
Originally Posted by openfoammaofnepo View Post
Dear Matvey,
Hi, faceProcAddresing
is a list of global faces indices for all
local processor internal faces followed by local processor boundary faces
some local processor boundary faces (processor boundaries) can be global internal faces
Old   November 17, 2015, 07:24
Thank you for your reply. Clear for me now.
Old   November 17, 2015, 09:57
Dear Matvey,
I have a special type of faces. The mesh is generated by ICEM with multiple bodies. Between bodies, there will be an interior faces. I always output the icem mesh using fluent v6 format. Then convert that mesh with fluent3DMeshToFoam to openfoam format. I am not sure for this interior faces, what does it belong for global mesh set and local processor mesh set. Do you have ideas about this? Thank you.
Old   November 17, 2015, 10:24
mkraposhin's Avatar
Matvey Kraposhin
Can you upload an example of your mesh?
Old   November 17, 2015, 11:07
The mesh is too big to put it here......
Old   November 17, 2015, 11:13
mkraposhin's Avatar
Matvey Kraposhin
I mean, can you make a simple example, that can be used as a tutorial? And then put it here
Old   November 17, 2015, 12:19
I have made some investigations, it seems that in faceProcAddressing file, the "interior" faces are counted in the boundary faces. But this is special, since they are not counted in the file as constant/polymesh/boundary (this is reasonable since for the global mesh, it is indeed interior faces). I check the original file, it is not similar to other physical boundaries, interior faces have both owner and neighbor cells. However, for the physical boundaries, they only have owner cell, the neighbor cell index is set to zero. This is very confusing here. I am still not sure how to label it in openfoam, because it does not appear in boundary list.
Old   November 17, 2015, 12:38
mkraposhin's Avatar
Matvey Kraposhin
I'm sorry, i didn't understood everything
But, as for owner/neighbor cells , the distinguish rule is simple:
- the face is called owner with respect to cell, when it's normal points outward of cell
- the face is called neighbor with respect to cell, when it's normal points inside the cell
Each boundary face can be connected only to one cell and we know, that surface of domain should have normal, pointing outward. So, all boundary faces are owners only
Old   November 17, 2015, 12:47
Thanks, but the parallel solver, does openfoam treat the inter-body faces as boundary or inteiror faces? How to extract the owner and neighbor cell index for the inter-body faces?
Old   November 17, 2015, 13:05
mkraposhin's Avatar
Matvey Kraposhin
If you call processor as *body*, then my answe is: yes, inter-processor faces are treated as boundary faces
Old   November 17, 2015, 13:09
No, here Body is from ICEM. That means a multi-block mesh, and different blocks (i.e. body) share one common surface.
Old   November 17, 2015, 13:14
mkraposhin's Avatar
Matvey Kraposhin
O.K.,
Actually, i don't know which structure OpenFOAM uses to represent ICEM body, that's why i asked you to upload any simple example
Old   November 10, 2017, 00:39
Vishwesh Ravi Shrimali
vishwesh is on a distinguished road
Hi!
Though this thread is about 2 years old but is pretty relevant to a problem that I am facing. (Neighboring cells in tetrahedral mesh)
To explain my problem in detail: (Considering parallel run)
1. I form a list of cell IDs with alpha > 0.3 for each processor and then merge these lists to form a mail list.
2. I iterate over each element of the main list, find the neighboring cells of the element and see how many of these neighboring cells have alpha > 0. These cells then end up becoming a part of a bubble.
The trouble that I have realized now is that because I am using parallel run, I might not be getting the global cellIDs and am only stuck with local IDs. Can anyone please help me out with this? What should I do...
Thank you in advance
vishwesh is offline   Reply With Quote
Old   November 10, 2017, 05:08
Hi, i'm not sure that i understand your question right, but i will try to give more explanation on the code, that i posted above.
For each MPI process (or processor) you can read addressing arrays, which maps local process indexation of primitives into global indexation of primitives. This arrays are located in folder processj/constant/polyMesh in next files
  boundaryProcAddressing
  cellProcAddressing
  faceProcAddressing
  pointProcAddressing
  • boundaryProcAddresing - each element contains global index of patch that is present on current process, for "processor" boundaries this index is -1. Size of this array is equal to number of patches in global mesh plus number of "processor" patches in current processorj folder or processor.
  • cellProcAddressing - each element contains global index of given local process cell. Size of this array is equal to number of cells in current processor
  • faceProcAddressing - each element contains global index of given local process face. Size of this array is equal to number of face in current processor
  • pointProcAddressing - each element contains global index of given local process point. Size of this array is equal to number of points in current processor
You can read this arrays in each MPI process with the code similar to next
	labelIOList localCellProcAddr
	    IOobject
		"cellProcAddressing",
		mesh.facesInstance(),
		mesh.meshSubDir,
		mesh,
		IOobject::MUST_READ,
		IOobject::NO_WRITE
or for faces
	labelIOList localFaceProcAddr
	    IOobject
		mesh.meshSubDir,
		mesh,
		IOobject::NO_WRITE
then you can store this addresing arrays in another arrays
processCellToGlobalAddr_[Pstream::myProcNo()] = localCellProcAddr;
Variable Pstream::myProcNo() contains id of process. In master process it's value will be 0, in process 1 it's value will be 1 and so on.
At this point array processCellToGlobalAddr_ contains information only about adressing of current process, adressing of other processes is invsible. That's why at next step step you need to redistribute this information across other processes. The idea is simple:
1) send addresing information from all processes to master process (with id #0)
2) send gather infromation from master process to other processes
	//send local cell addressing to master process
	if (Pstream::master())
	    for (label jSlave=Pstream::firstSlave(); jSlave<=Pstream::lastSlave(); jSlave++)
		IPstream fromSlave(Pstream::scheduled, jSlave);
		label nSlaveCells = 0;
		fromSlave >> nSlaveCells;
		processCellToGlobalAddr_[jSlave].resize(nSlaveCells);
		labelList& slaveCellProcAddr = processCellToGlobalAddr_[jSlave];
		forAll(slaveCellProcAddr, iCell)
		    fromSlave >> slaveCellProcAddr[iCell];
	else
	    OPstream toMaster (Pstream::scheduled, Pstream::masterNo());
	    toMaster << localCellProcAddr.size();
	    forAll(localCellProcAddr, iCell)
		toMaster << localCellProcAddr[iCell];
	//redistribute cell addressing to slave processes
		OPstream toSlave (Pstream::scheduled, jSlave);
		forAll(processCellToGlobalAddr_, iProcess)
		    const labelList& thisProcessAddr = processCellToGlobalAddr_[iProcess];
		    const label nCells = thisProcessAddr.size();
		    toSlave << nCells;
		    forAll(thisProcessAddr, jCell)
			toSlave << thisProcessAddr[jCell];
	else
	    IPstream fromMaster(Pstream::scheduled, Pstream::masterNo());
		label nCells = 0;
		fromMaster >> nCells;
		thisProcessAddr.resize(nCells);
		    fromMaster >> thisProcessAddr[jCell];
At the last step we may need to create reverse addressing - from global cell id to local process cell id (or face id, or point id):
	forAll(processCellToGlobalAddr_, jProc)
	    const labelList& jProcessAddr = processCellToGlobalAddr_[jProc];
	    forAll(jProcessAddr, iCell)
		label iGlobalCell = jProcessAddr[iCell];
		globalCellToProcessAddr_[iGlobalCell] = iCell;
Hi!
I was trying out the code for a problem that I am facing. I changed localmesh to mesh and removed "_" from the variable names too. I was able to compile the solver properly, but somehow it's not working properly. I am attaching the code and the result here. I would be very grateful if you could help me out with it.
        Info<<"\n\nEntering addressing array transfer to Master processor\n\n";
        /*============TRANSFER CELL INDEX FROM SLAVE TO MASTER=============*\
         |The local cell index from each processor folder will be obtained |
         |from cellProcAddressing array. This data will contain the local  |
         |cell ID and global cell ID. This data will be transferred to the |
         |master processor for gathering the data.                         |
         // for transferring process cell ID to global cell ID
         List<List<label> > processCellToGlobalAddr;
         // for transferring global cell ID to process cell ID
         List<label> globalCellToProcessAddr;
         if (RUN_IN_PARALLEL)
            processCellToGlobalAddr.resize
                Pstream::nProcs()
            // read local cell addressing
                IOobject
                    mesh.meshSubDir,
                    mesh,
                    IOobject::NO_WRITE
            // store addressing arrays in different array
            processCellToGlobalAddr[Pstream::myProcNo()] = localCellProcAddr;
            // Redistribute this information across other processes as follows:
            // > send addressing information from all processors to Master Processor
            // > Gather information at master processor
            // > Send gathered information from master processor to other processors
            // send local cell addressing to master processor
                    Pout<<"I worked first"<<endl;
                    processCellToGlobalAddr[jSlave].resize(nSlaveCells);
                    labelList& slaveCellProcAddr = processCellToGlobalAddr[jSlave];
//                    Pout<<"slave: "<<jSlave<<"\nslaveCellProcAddr:\n"<<slaveCellProcAddr<<"\nprocessCellToGlobalAddr:\n"<<processCellToGlobalAddr<<endl;
            else
                Pout<<"I worked"<<endl;
//                Pout<<"localCellProcAddr:\n"<<localCellProcAddr<<endl;
            Info<<"\nInformation transferred to master processor.\nBeginning cell addressing redistribution to slave processes.\n\n";
            // redistribute cell addressing to slave processes
                    Pout<<"I worked too"<<endl;
                    forAll(processCellToGlobalAddr, iProcess)
                        const labelList& thisProcessAddr = processCellToGlobalAddr[iProcess];
                        toSlave << nCells;
            else
                Pout<<"I worked second"<<endl;
                    label nCells = 0;
//                    Pout<<"thisProcessAddr:\n"<<thisProcessAddr<<endl;
            // reverse addressing:- from global cell ID to local process cell ID
            Info<<"\nInformation transferred to slave processes.\nBeginning conversion of global cell ID to local process cell ID.\n\n";
            forAll(processCellToGlobalAddr, jProc)
                const labelList& jProcessAddr = processCellToGlobalAddr[jProc];
                    globalCellToProcessAddr[iGlobalCell] = iCell;
//            Pout<<"globalCellToProcessAddr:\n"<<globalCellToProcessAddr<<endl;
            Info<<"\nReverse addressing complete.\n\n";
Here is the result:
[12] I worked
[24] I worked
[29] I worked
[0] I worked first
[6] I worked
[10] I worked
[2] I worked
[18] I worked
[27] I worked
[21] I worked
[31] I worked
[1] I worked
[9] I worked
[3] I worked
[1] I worked second
[15] I worked
[0] I worked first
[2] I worked second
[26] I worked
[3] I worked second
[16] I worked
[0] I worked first
[0] I worked first
[4] I worked
[13] I worked
[4] I worked second
[28] I worked
[0] I worked first
[19] I worked
[22] I worked
[20] I worked
[25] I worked
[11] I worked
[30] I worked
[5] I worked
[5] I worked second
[6] I worked second
[17] I worked
[0] I worked first
[14] I worked
[0] I worked first
[23] I worked
[7] I worked
[7] I worked second
[0] I worked first
[8] I worked
[8] I worked second
[10] I worked second
[9] I worked second
[0] I worked first
[0] I worked first
[12] I worked second
[11] I worked second
[0] I worked first
[0] I worked first
[13] I worked second
[14] I worked second
[0] I worked first
[0] I worked first
[0] I worked first
[0] I worked first
[15] I worked second
[16] I worked second
[0] I worked first
[0] I worked first
[17] I worked second
[18] I worked second
[0] I worked first
[0] I worked first
[19] I worked second
[20] I worked second
[0] I worked first
[0] I worked first
[21] I worked second
[22] I worked second
[0] I worked first
[23] I worked second
[0] I worked first
[24] I worked second
[0] I worked first
[25] I worked second
[0] I worked first
[26] I worked second
[0] I worked first
[27] I worked second
[0] I worked first
[28] I worked second
[0] I worked first
[29] I worked second
[31] I worked second
[30] I worked second
[0] I worked first
[0] I worked first
[0] I worked too
[0] I worked too
[1] #0  Foam::error::printStack(Foam::Ostream&)[0] I worked too
 in "/share/OpenFOAM/OpenFOAM-3.0.x/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so"
[1] #1  Foam::sigSegv::sigHandler(int)[0] I worked too
[2] #0  Foam::error::printStack(Foam::Ostream&) in "/share/OpenFOAM/OpenFOAM-3.0.x/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so"
[1] #2  ?[0] I worked too
[2] #1  Foam::sigSegv::sigHandler(int)[3] #0  Foam::error::printStack(Foam::Ostream&) at sigaction.c:0
[1] #3  main in "/share/OpenFOAM/OpenFOAM-3.0.x/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so"
[2] #2  ? in "/hom in "/share/OpenFOAM/OpenFOAM-3.0.x/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so"
e[3] #1  Foam::sigSegv::sigHandler(int)/[0] I worked too
vshrima/OpenFOAM/vshrima-3.0.x/platforms/linux64GccDPInt64Opt/bin/myLPTVOF_RP_test"
[1] #4  __libc_start_main at sigaction.c:0
[2] #3  [4] #0  Foam::error::printStack(Foam::Ostream&)main in "/share/OpenFOAM/OpenFOAM-3.0.x/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so"
[3] #2  ? in "/lib64/libc.so.6"
[1] #5  ? at sigaction.c:0
[3] #3   in "/home/vshrima/OpenFOAM/vshrima-3.0.x/platforms/linux64GccDPInt64Opt/bin/myLPTVOF_RP_test"
[2] #4  __libc_start_main in "/share/OpenFOAM/OpenFOAM-3.0.x/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so"
[4] #1  Foam::sigSegv::sigHandler(int)[0] I worked too
main in "/home/vshrima/OpenFOAM/vshrima-3.0.x/platforms/linux64GccDPInt64Opt/bin/myLPTVOF_RP_test"
[cgscd000ggb3t92:35078] *** Process received signal ***
[cgscd000ggb3t92:35078] Signal: Segmentation fault (11)
[cgscd000ggb3t92:35078] Signal code:  (-6)
[cgscd000ggb3t92:35078] Failing at address: 0x11e7d00008906
[cgscd000ggb3t92:35078] [ 0] /lib64/libc.so.6[0x3eb7c32510]
[cgscd000ggb3t92:35078] [ 1] /lib64/libc.so.6(gsignal+0x35)[0x3eb7c32495]
[cgscd000ggb3t92:35078] [ 2] /lib64/libc.so.6[0x3eb7c32510]
[cgscd000ggb3t92:35078] [ 3] myLPTVOF_RP_test(main+0x22e7)[0x448bf7]
[cgscd000ggb3t92:35078] [ 4] /lib64/libc.so.6(__libc_start_main+0xfd)[0x3eb7c1ed1d]
[cgscd000ggb3t92:35078] [ 5] myLPTVOF_RP_test[0x446439]
[cgscd000ggb3t92:35078] *** End of error message ***
[2] #5  [5] #0  Foam::error::printStack(Foam::Ostream&) in "/home/vshrima/OpenFOAM/vshrima-3.0.x/platforms/linux64GccDPInt64Opt/bin/myLPTVOF_RP_test"
[3] #4  __libc_start_main? in "/share/OpenFOAM/OpenFOAM-3.0.x/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so"
[4] #2  ? in "/lib64/libc.so.6"
[3] #5  [6] #0  Foam::error::printStack(Foam::Ostream&) in "/home/vshrima/OpenFOAM/vshrima-3.0.x/platforms/linux64GccDPInt64Opt/bin/myLPTVOF_RP_test"
[cgscd000ggb3t92:35079] *** Process received signal ***
[cgscd000ggb3t92:35079] Signal: Segmentation fault (11)
[cgscd000ggb3t92:35079] Signal code:  (-6)
[cgscd000ggb3t92:35079] Failing at address: 0x11e7d00008907
[cgscd000ggb3t92:35079] [ 0] /lib64/libc.so.6[0x3eb7c32510]
[cgscd000ggb3t92:35079] [ 1] /lib64/libc.so.6(gsignal+0x35)[0x3eb7c32495]
[cgscd000ggb3t92:35079] [ 2] /lib64/libc.so.6[0x3eb7c32510]
[cgscd000ggb3t92:35079] [ 3] myLPTVOF_RP_test(main+0x22e7)[0x448bf7]
[cgscd000ggb3t92:35079] [ 4] /lib64/libc.so.6(__libc_start_main+0xfd)[0x3eb7c1ed1d]
[cgscd000ggb3t92:35079] [ 5] myLPTVOF_RP_test[0x446439]
[cgscd000ggb3t92:35079] *** End of error message ***
? at sigaction.c:0
[4] #3   in "/share/OpenFOAM/OpenFOAM-3.0.x/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so"
[0] I worked too
[5] #1  Foam::sigSegv::sigHandler(int) in "/home/vshrima/OpenFOAM/vshrima-3.0.x/platforms/linux64GccDPInt64Opt/bin/myLPTVOF_RP_test"
[cgscd000ggb3t92:35080] *** Process received signal ***
[cgscd000ggb3t92:35080] Signal: Segmentation fault (11)
[cgscd000ggb3t92:35080] Signal code:  (-6)
[cgscd000ggb3t92:35080] Failing at address: 0x11e7d00008908
[cgscd000ggb3t92:35080] [ 0] /lib64/libc.so.6[0x3eb7c32510]
[cgscd000ggb3t92:35080] [ 1] /lib64/libc.so.6(gsignal+0x35)[0x3eb7c32495]
[cgscd000ggb3t92:35080] [ 2] /lib64/libc.so.6[0x3eb7c32510]
[cgscd000ggb3t92:35080] [ 3] myLPTVOF_RP_test(main+0x22e7)[0x448bf7]
[cgscd000ggb3t92:35080] [ 4] /lib64/libc.so.6(__libc_start_main+0xfd)[0x3eb7c1ed1d]
[cgscd000ggb3t92:35080] [ 5] myLPTVOF_RP_test[0x446439]
[cgscd000ggb3t92:35080] *** End of error message ***
[6] #1  Foam::sigSegv::sigHandler(int) in "/home/vshrima/OpenFOAM/vshrima-3.0.x/platforms/linux64GccDPInt64Opt/bin/myLPTVOF_RP_test"
[4] #4  __libc_start_main in "/share/OpenFOAM/OpenFOAM-3.0.x/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so"
[5] #2  ? in "/share/OpenFOAM/OpenFOAM-3.0.x/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so"
[6] #2  ? in "/lib64/libc.so.6"
[4] #5   at sigaction.c:0
[5] #3  ? in "/home/vshrima/OpenFOAM/vshrima-3.0.x/platforms/linux64GccDPInt64Opt/bin/myLPTVOF_RP_test"
[cgscd000ggb3t92:35081] *** Process received signal ***
[cgscd000ggb3t92:35081] Signal: Segmentation fault (11)
[cgscd000ggb3t92:35081] Signal code:  (-6)
[cgscd000ggb3t92:35081] Failing at address: 0x11e7d00008909
[cgscd000ggb3t92:35081] [ 0] /lib64/libc.so.6[0x3eb7c32510]
[cgscd000ggb3t92:35081] [ 1] /lib64/libc.so.6(gsignal+0x35)[0x3eb7c32495]
[cgscd000ggb3t92:35081] [ 2] /lib64/libc.so.6[0x3eb7c32510]
[cgscd000ggb3t92:35081] [ 3] myLPTVOF_RP_test(main+0x22e7)[0x448bf7]
[cgscd000ggb3t92:35081] [ 4] /lib64/libc.so.6(__libc_start_main+0xfd)[0x3eb7c1ed1d]
[cgscd000ggb3t92:35081] [ 5] myLPTVOF_RP_test[0x446439]
[cgscd000ggb3t92:35081] *** End of error message ***
 at sigaction.c:0
[6] #3  main in "/home/vshrima/OpenFOAM/vshrima-3.0.x/platforms/linux64GccDPInt64Opt/bin/myLPTVOF_RP_test"
[6] #4  __libc_start_main in "/lib64/libc.so.6"
[6] #5  ? in "/home/vshrima/OpenFOAM/vshrima-3.0.x/platforms/linux64GccDPInt64Opt/bin/myLPTVOF_RP_test"
[cgscd000ggb3t92:35083] *** Process received signal ***
[cgscd000ggb3t92:35083] Signal: Segmentation fault (11)
[cgscd000ggb3t92:35083] Signal code:  (-6)
[cgscd000ggb3t92:35083] Failing at address: 0x11e7d0000890b
[cgscd000ggb3t92:35083] [ 0] /lib64/libc.so.6[0x3eb7c32510]
[cgscd000ggb3t92:35083] [ 1] /lib64/libc.so.6(gsignal+0x35)[0x3eb7c32495]
[cgscd000ggb3t92:35083] [ 2] /lib64/libc.so.6[0x3eb7c32510]
[cgscd000ggb3t92:35083] [ 3] myLPTVOF_RP_test(main+0x22e7)[0x448bf7]
[cgscd000ggb3t92:35083] [ 4] /lib64/libc.so.6(__libc_start_main+0xfd)[0x3eb7c1ed1d]
[cgscd000ggb3t92:35083] [ 5] myLPTVOF_RP_test[0x446439]
[cgscd000ggb3t92:35083] *** End of error message ***
(shortened)
Thanks in advance
Old   April 24, 2020, 16:15
Default localToGlobal cell mapping in a dynamic mesh refinement case
  #40
mehrabadi is on a distinguished road
You can read cellProcAddresing arrays from processor0 ... processorN folders
see example below
List<List<label> > processCellToGlobalAddr_;
List<label> globalCellToProcessAddr_;
    if (Pstream::parRun())
	processCellToGlobalAddr_.resize
	    Pstream::nProcs()
	//read local cell addressing
	    IOobject
		localMesh.facesInstance(),
		localMesh.meshSubDir,
		localMesh,
		IOobject::NO_WRITE
	else
		    toSlave << nCells;
	else
		label nCells = 0;
This approach is very insightful. Thank you for sharing. I understand that the initial local-to-global mapping is read from the disk and then distributed among all processors. My question is what happens when there is mesh refinement during the run-time where cell connectivity and numbering change locally. With number of cells and connectivity potentially changing in an adaptive mesh refinement case, do you have some suggestions how to update "globalCellToProcessAddr_" array?
mehrabadi is offline   Reply With Quote
