help compiling AddBoundaryDiag
Old   October 21, 2015, 10:26
Default help compiling AddBoundaryDiag
martel is on a distinguished road
Hi all,
I am trying to se the effect of the boundary conditions on the matrix diagonal coefficients for a very simple laplacian operator.
I use this simple code:
// Define a matrix that contains the coefficients of the Laplacian
    tmp<fvScalarMatrix> TEqnLaplaciano
	   fvm::laplacian(DT,T)
// Add BC contribution to matrix diagonal
     scalarField& diag    = TEqnLaplaciano().diag();
     TEqnLaplaciano().addBoundaryDiag(diag,0);
But it does not compile. I get the compilation error:
In file included from /opt/openfoam240/src/finiteVolume/lnInclude/fvMatrix.H:1058:0,
                 from /opt/openfoam240/src/finiteVolume/lnInclude/ddtScheme.C:29,
                 from /opt/openfoam240/src/finiteVolume/lnInclude/ddtScheme.H:325,
                 from /opt/openfoam240/src/finiteVolume/lnInclude/fvcDdt.C:28,
                 from /opt/openfoam240/src/finiteVolume/lnInclude/fvcDdt.H:199,
                 from /opt/openfoam240/src/finiteVolume/lnInclude/fvc.H:44,
                 from /opt/openfoam240/src/finiteVolume/lnInclude/fvCFD.H:8,
                 from laplacianFoam.C:32:
/opt/openfoam240/src/finiteVolume/lnInclude/fvMatrix.C: In function ‘int main(int, char**)’:
/opt/openfoam240/src/finiteVolume/lnInclude/fvMatrix.C:116:6: error: ‘void Foam::fvMatrix<Type>::addBoundaryDiag(Foam::scalarField&, Foam::direction) const [with Type = double; Foam::scalarField = Foam::Field<double>; Foam::direction = unsigned char]’ is protected
laplacianFoam.C:54:45: error: within this context
Related to some variables protected (??). And I don't know how to solve this protection problem.
Any help would be greatly welcome
Regards,
--CME
martel is offline   Reply With Quote
Problem with Compiling UDFs in Ansys Fluent 13 (lnx64) Ali.beh Fluent UDF and Scheme Programming 3 August 27, 2018 05:22
[OpenFOAM.org] Trouble Compiling OpenFOAM-dev using Intel Compiler 15 for use on Xeon Phi foamer123 OpenFOAM Installation 9 August 20, 2015 15:03
compiling problem of a mass transfer udf majid_kamyab FLUENT 9 October 15, 2014 11:18
Help with KIVA4 source code compiling geothokar Main CFD Forum 0 September 3, 2010 06:40
Discussing UDF and C++ Compiling Big Stone FLUENT 9 April 12, 2004 16:07
