Wall heat transfer boundary condition
Old   October 15, 2015, 07:29
Default Wall heat transfer boundary condition
Francesco Capuano
francesco_capuano is on a distinguished road
I would like to model a radiative and convective heat transfer through a wall.
In practice, I would need an equilibrium boundary condition of the type
\dot{q_w} = -\lambda \left(\dfrac{\partial T}{\partial n}\right)_w = \sigma\epsilon \left(T_w^4-T_e^4\right) + h\left(T_w-T_e \right),
where T_w is the wall temperature and T_e is the environment temperature outside the domain. The wall temperature would then be calculated from (a discretized version of) the above equation to yield the heat flux exchanged at the wall.
Is there any available boundary condition to model such problem?
Or, did anyone encounter the same issue (and maybe developed a customized b.c.)?
Many thanks in advance.
francesco_capuano is offline   Reply With Quote
Old   October 18, 2015, 12:52
akidess's Avatar
Anton Kidess
A mixed boundary condition (i.e. groovyBC) should do the trick. I'm sure you can find a copy&paste solution here on the forum.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   October 19, 2015, 07:11
Default GroovyBC
Napoli
Simeone_Parolisi is on a distinguished road
We successfully modeled it with this implementation in file 'T' in directory '0'
boundaryField
fixedWalls
type groovyBC;
refValue uniform 288;
refGradient uniform 0;
valueFraction uniform 1;
value uniform 288;
valueExpression "0";
gradientExpression "h*(T-Tinf)+(sigma)*E*(T*T*T*T-Tinf*Tinf*Tinf*Tinf)";
fractionExpression "0";
evaluateDuringConstruction 0;
variables
4
"h=50;"
"sigma=5.6e-8;"
"E=0.8;"
"Tinf=288;"
After, we was forced to change the string thermoType>energy from 'sensibleEnthalpy' to 'sensibleInternalEnergy' in file 'thermophysicalProperties' in directory 'constant' for other reasons and we obtained a floating point exception error.
What is the problem? Is there an alternative method to implement heat transfer written above?
Simeone_Parolisi is offline   Reply With Quote
heat transfer, radiation, wall boundary condition
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Thin Wall Heat Transfer BC for rhoSimpleFoam swahono OpenFOAM Running, Solving & CFD 12 October 4, 2013 12:49
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 21:11
