Error making a new utility code: "cyclicAMILduInterface.H: No such file or directory"
Like Tree26Likes
Old   October 11, 2018, 04:21
Vince
hyFoam is on a distinguished road
Please open a new thread with those errors then.
For info, you'll find on my github a function object to calculate the Stanton number from the wall heat flux in OF-v1706. You could start from that.
https://github.com/vincentcasseau/hy...No/StantonNo.C
And here's how you would use it:
https://github.com/vincentcasseau/hy...faceQuantities
https://github.com/vincentcasseau/hy...ceCoefficients
calling surfaceQuantities in the controlDict and running in a terminal window:
<solverName> -postProcess -dict 'system/surfaceCoefficients' -latestTime
Thanks,
Vince
hyFoam is offline   Reply With Quote
Old   September 25, 2019, 17:37
Default hi Antimony
  #22
kevin
kevinlin is on a distinguished road
Hi Antimony
I solved it! Thank you very much:d:d
kevinlin is offline   Reply With Quote
Old   February 22, 2020, 07:12
Ashish Magar
ashishmagar600 is on a distinguished road
Sorry posted on the wrong thread.
ashishmagar600 is offline   Reply With Quote
Old   April 2, 2020, 12:39
Alejandro
ancolli is on a distinguished road
Originally Posted by Gbaz View Post
Thanks for your reply. No I didn't fix it.
I am facing the same problem when using openFoam dev. did u solve ur problem?
ancolli is offline   Reply With Quote
Old   April 23, 2020, 08:18
Kabir Shariff
Kbshariff is on a distinguished road
Dear foamers,
I have a similiar error, I want to add the foamcalcex on OF 7.
I am a newbie, I make directory is not clear for me.
i need you assistance please.
Here is the error message
~/foamcalcex/postProcessing ~/foamcalcex
+ wmake libo postCalc
wmake libo postCalc
+ wmake libso foamCalcFunctionsEx
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam7/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam7/src/OpenFOAM/lnInclude -I/opt/openfoam7/src/OSspecific/POSIX/lnInclude -fPIC -c calcType/calcType.C -o Make/linux64GccDPInt32Opt/calcType/calcType.o
In file included from /opt/openfoam7/src/finiteVolume/lnInclude/ddtScheme.C:30:0,
from /opt/openfoam7/src/finiteVolume/lnInclude/ddtScheme.H:357,
from /opt/openfoam7/src/finiteVolume/lnInclude/fvcDdt.C:28,
from /opt/openfoam7/src/finiteVolume/lnInclude/fvcDdt.H:250,
from /opt/openfoam7/src/finiteVolume/lnInclude/fvc.H:44,
from /opt/openfoam7/src/finiteVolume/lnInclude/fvCFD.H:8,
from calcType/calcType.H:48,
from calcType/calcType.C:26:
/opt/openfoam7/src/finiteVolume/lnInclude/cyclicAMIFvPatch.H:39:10: fatal error: cyclicAMILduInterface.H: No such file or directory
#include "cyclicAMILduInterface.H"
compilation terminated.
/opt/openfoam7/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/calcType/calcType.o' failed
make: *** [Make/linux64GccDPInt32Opt/calcType/calcType.o] Error 1
regards,
Kabir
Kbshariff is offline   Reply With Quote
Old   October 14, 2020, 15:49
Alejandro
Solved here: cyclicAMILduInterface.H OF 8 and dev
Old   October 29, 2021, 18:40
zink
ansab_sindhu is on a distinguished road
I am also trying to fix the issue where it says
/opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/cyclicAMIFvPatch.H:41:35: fatal error: cyclicAMILduInterface.H: No such file or directory
I have to calculate the heat transfer coefficient around cylinder. Any help will be appreciated
ansab_sindhu is offline   Reply With Quote
Old   July 7, 2023, 08:42
Uttam
openfoam_aero is on a distinguished road
Originally Posted by Antimony View Post
Hi All,
To anyone else who is still facing this problem (like I did for a couple of hours recently), please note that the solution given works, provided it is the first one included.
That is, if you have (for example)
EXE_INC = \
-I$(LIB_SRC)/someLibrary
Change it to this:
EXE_INC = \
-I$(LIB_SRC)/meshTools/lnInclude \
The reason I type this is because I distinctly remember putting the original hint into the options file, but I still had errors. However, when I changed the order, it seemed to work.
Again, it might have been a one-off, but if anyone else faced the same issue, give this method a shot as well.
Thanks alexeym for the original solution!
Cheers,
Antimony
Thanks a lot, this worked for me
Best Regards
Uttam
“When everything seem to be going against you, remember that the airplane takes off against the wind, not with it.” – Henry Ford.
openfoam_aero is offline   Reply With Quote
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 09:46
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
