multi region problem in developing a new solver
Old   September 21, 2015, 01:54
Default multi region problem in developing a new solver
nemo
huyidao is on a distinguished road
Hello,Foamers.
I am using the openfoam 2.4.0, and trying to write a new solver which is similar to chtMultiRegionFoam , here are my problems.
First, I need to solve equations in the entire domain both in the fluid part and solid part, and I want this equation to be discretized into only one matrix A, in which the interface between fluid and solid need not to be treated as boundary.
Second, solve the equations in the fluid part. Some calculated result in the first step needed to be transferred to this step as the energy source, but only in the fluid part .
How to implement this? Can anyone give me some advice? Thanks a lot.
huyidao is offline   Reply With Quote
Old   May 17, 2016, 08:28
Karelke Yu
cfdopenfoam is on a distinguished road
Originally Posted by huyidao View Post
Hello,Foamers.
greetings,
I am facing the same problem. have you got a method to do this?
cfdopenfoam is offline   Reply With Quote
Can I use fvOptions to couple a solid region and a fluid region? titanchao OpenFOAM Running, Solving & CFD 4 January 14, 2022 08:55
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
Suggestions for a multi region conjugate heat transfer problem maddalena OpenFOAM 14 September 4, 2013 19:03
Divergence problem Smaras FLUENT 13 February 21, 2013 06:03
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
