September 11, 2015, 04:14 |
Acoustic Perturbation Equations (APE)
Sergej
Rep Power: 11 |
Hello everybody,
i am new at OpenFoam, but i read much theory of it and now I would like to implement the Acoustic Perturbation Equations (APE) in OpenFoam. I think it would not be very easy, so i hope that maybe somebody here have made experience with it. Here is the relevante paper link: http://www.sciencedirect.com/science...21999103001682 If you are a student, then it is mybe for free, if you log in with VPN of your university. So if i get some experience with it i will share it here. |
February 24, 2016, 15:50 |
Hasan K.J.
Rep Power: 15 |
Dear Tonky,
By any chance did you have any luck in implementing APE in OpenFOAM. Regards, Hasan K.J
"Real knowledge is to know the extent of one's ignorance." - Confucius |
September 27, 2016, 11:20 |
Sergej
Rep Power: 11 |
Hello Hasan,
after some practice with OF, I have started to work further on the implementation of APE-2 theory. But now I am facing some problems, which I am now trying to solve, also with the help of cfd-online.com. I noticed that the equations of "APE-2" are similar to the equations of Seo and Moon in "Linearized Perturbed Compressible Equations": http://www.cfd-online.com/Wiki/Hydro...stic_splitting But my problem is now that i implemented the following three equations (see attached files) and I am solving them on the explicit way (diagonal solver) and the values of rho' and u' are increasing during the simulation without a limit. Now I am trying to implement them on the implicit way. Is this possible and if yes, how? Hasan, did you have some experience with APE? |
September 30, 2016, 06:44 |
how to solve coupled equations?
Sergej
Rep Power: 11 |
Hello Foamers,
I have read many posts here in cfd-online, but could not solve my problems with the iterations with the number of zero. I implemented the three equations in the following form: Code:
solve(fvm::ddt(rhoS)+ rhoS * (fvc::div(averageU)) == - rho * (fvc::div(Ua)) ); Code:
solve(fvm::ddt(Ua)+ fvc::grad(averageU & Ua) == - fvc::grad(pa)); Code:
solve(rho*fvm::ddt(pa)- c0*c0*fvc::ddt(rhoS) == - rho*fvc::ddt(pS)); |
January 21, 2018, 23:20 |
Dear Tonky, Have you solved your problems?
#5 | |
Rep Power: 8 |
I'm getting in trouble with APE in OpenFOAM too...Thanks!
October 24, 2024, 01:50 |
Rep Power: 4 |
another form of APE might be easier to implement in OpenFOAM. In the work of Maurerlehner et al., they introduced the scalar acoustic potential and solve the equation of it. Then acoustic pressure can be calculated in post-processing step. Maurerlehner, P., Schoder, S., Tieber, J., Freidhager, C., Steiner, H., Brenn, G., Schäfer, K., Ennemoser, A., & Kaltenbacher, M. (2022). Aeroacoustic formulations for confined flows based on incompressible flow data. Acta Acustica. https://1drv.ms/i/s!App_wgTsRcZ5gsgb...ofyhg?e=T99enV |
acoustic, aeroacoustics, implementation, open foam, perturbation equations |
Guide: Writing Equations in LaTeX on the CFD Online Forums | pete | Site Help, Feedback & Discussions | 27 | May 19, 2022 04:19 |
how to solver perturbation equations of navier stokes equations ? | mechy | OpenFOAM Programming & Development | 1 | June 8, 2014 18:04 |
modelling Differential equations in a udf | RikardMNorén | Fluent UDF and Scheme Programming | 2 | October 1, 2013 04:36 |
CFD governing equations | m.gos | Main CFD Forum | 0 | April 30, 2011 15:21 |
exact solution of acoustic equations | pran | Main CFD Forum | 0 | February 14, 2002 03:46 |
