The density cross the interface is incorrect in the KEpsilon model in interFoam?
Old   August 14, 2015, 12:40
Default The density cross the interface is incorrect in the KEpsilon model in interFoam?
duan
duan is on a distinguished road
Recently I have found a paper (OMAE2015-41812) discussed about the KEpsilon model in the interFoam (2.3.0), which claimed that "The existing formulations treat the density as a constant without considering its variations crossing the air and water free surface which is not correct. "
See the attached pic for more details.
I then checked KEpsilon.C, for the Dissipation equation
    tmp<fvScalarMatrix> epsEqn
        fvm::ddt(epsilon_)
      + fvm::div(phi_, epsilon_)
      - fvm::laplacian(DepsilonEff(), epsilon_)
        C1_*G*epsilon_/k_
      - fvm::Sp(C2_*epsilon_/k_, epsilon_)
and the turbulent kinetic energy equation
    tmp<fvScalarMatrix> kEqn
        fvm::ddt(k_)
      + fvm::div(phi_, k_)
      - fvm::laplacian(DkEff(), k_)
        G
      - fvm::Sp(epsilon_/k_, k_)
and G , G = $P_k$
volScalarField G(GName(), nut_*2*magSqr(symm(fvc::grad(U_))));
It seems the equation described in this paper is correct. However assuming the fluid is incompressible, for each phase (water or air), the density could be treated as a constant and remove from the Dissipation equation and energy equation. It does not sounds like a mistake. But of course we need to check the different density of water and air is accounted in the momentum equation.
Then I checked the UEqn in interFoam (2.3.0), which reads,
fvVectorMatrix UEqn
        fvm::ddt(rho, U)
      + fvm::div(rhoPhi, U)
      + turbulence->divDevRhoReff(rho, U)
and the divDevRhoReff(rho,U) also in KEpsilon.C,
tmp<fvVectorMatrix> kEpsilon::divDevRhoReff
    const volScalarField& rho,
    volVectorField& U
) const
    volScalarField muEff("muEff", rho*nuEff());
    return
      - fvm::laplacian(muEff, U)
      - fvc::div(muEff*dev(T(fvc::grad(U))))
It seems in the UEqn, the same rho is passed to the turbulence model.
Now I have the questions, which is this "const volScalarField& rho"?
It is rho_water, rho_air, or rho = alpha.water*rho_water + alpha.air*rho_air, with alpha.air = 1 - alpha.water?
Do you guys think the treatment in interFoam is correct or not?
The paper is linked here:
https://www.dropbox.com/s/53nvxo79m8...41812.pdf?dl=0
duan is offline   Reply With Quote
Current density visualisation (PEM fuel cell add-on module) pchoopanya FLUENT 10 August 21, 2023 15:33
How to change turbulence model in InterFoam Gildeh OpenFOAM Running, Solving & CFD 4 March 28, 2012 13:04
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
