vof with cht
Old   July 28, 2015, 12:43
Default vof with cht
Kapa Lilla
klilla is on a distinguished road
Dear All,
I try to develop a solver: incompressible 2phase, temperature dependent VOF flow solver embedded in the cht multiregion environment.
What I have: vof+temperature without cht working fine
cht + single phase solver working fine
Where I fail is the definition of alpha (void fraction) in the multiregion environment. My alpha do not get updated if I try:
creatFluidFields.H : PtrList<volScalarField> alpha1Fluid(fluidRegions.size());
alpha1Fluid.set
i,
new volScalarField
thermoFluid[i].alpha1()
setRegionFluidFields.H: volScalarField& alpha1 = alpha1Fluid[i];
I thought to do it in an other way:
creatFluidFields.H : nothing of alpha1
setRegionFluidFields.H: volScalarField& alpha1 = thermo.alpha1();
with thermo = thermoFluid[i]
This is updating the field, but just close to the walls and gives very wierd results, though the equations I'm solving are the same as I use for the solver without cht.
Can anyone help?
Thanks,
Lilla
klilla is offline   Reply With Quote
Old   July 29, 2015, 03:48
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
You may need to adapt the CHT boundary conditions to take into account the variable density and viscosity (and thus the local heat transfer coeffs)..
Just a guess!
Kyle
kmooney is offline   Reply With Quote
Old   July 29, 2015, 06:30
Kapa Lilla
Dear Kyle,
thanks for your answer. In fact, that I did already. In any case, right now I run an isotherm case, my problem is that the free-surface is not moving...
Thanks again,
Lilla
cht coupling, vof
VOF Inlet condition Rizwan FLUENT 15 July 5, 2018 17:33
HELP! adding a mass source to VOF eqn. by UDF??? ROOZBEH FLUENT 5 December 3, 2016 18:53
UDF Defining VOF Free Surface at Outlet Alex Fluent UDF and Scheme Programming 13 August 8, 2012 17:50
problem about VOF and species couple Cloud FLUENT 0 June 15, 2012 02:23
Difficult BCs about Freesurface Simulation by VOF Yongguang Cheng FLUENT 0 September 19, 2003 08:39
