Dimensioned Tensor: having diagonal terms which are not predefined constant
Old   July 23, 2015, 13:39
Default Dimensioned Tensor: having diagonal terms which are not predefined constant
Paolo Capobianchi
pablitobass is on a distinguished road
Hello everyone,
I would like to ask if someone can tell me if it is possible to define a dimensionedSymmtensor having diagonal terms which are not predefined constant (variables, let say).
In practice I would like to know if it is possible to define an "object " like this:
    D_
        dimensionedSymmTensor
            "D",
            dimensionSet(0, 0, 0, 0, 0, 0, 0),
            symmTensor
               D_.xx , 0, 0,
                    D_.yy, 0,
                        D_.zz
Furtherome, is it is possible to convert it in a "volTensorField"? I must to manipulate it with other objects that are defined in this manner.
Thank you very much in advance.
Regards,
Paolo
pablitobass is offline   Reply With Quote
Old   July 25, 2015, 13:11
Paolo Capobianchi
I have just found another way to define the volumeTensorField
    return tmp<Foam::volTensorField>
        new volTensorField
            IOobject
                "D",
                localtimeName,
                *localmesh,
                IOobject::NO_READ,
                IOobject::NO_WRITE
            *localmesh
It compile fine but I cannot define the diagonal tensor field I need. If I have understood correctly, by using the following operation: diag(T) give the diagonal of the matrix T, which is obviously a matrix as well. Since in my case D is a volTensorField, that operation is not allowed.
Furthermore, I have another tensor field A, and my goal is to obtain D as the diagonal of the field A.
Does anyone knows if there is a way around to get the diagonal of a tensor field?
Thanks
Paolo
why divergence occures in these cases immortality OpenFOAM Running, Solving & CFD 2 January 25, 2013 11:21
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
Really big problems when creating own materials da Jop FLUENT 0 June 28, 2007 12:15
constant and exotic source terms in NS eq Mika FLUENT 2 September 6, 2001 09:55
