Particle induced turbulence model - kEpsilon with additional source
Old   July 21, 2015, 06:40
Default Particle induced turbulence model - kEpsilon with additional source
Andreas Weber
a.weber is on a distinguished road
Hello everyone,
since i am working on a euler-lagrangian simulation of bubblecolumns, i stumbled over some papers concerning bubble (or particle) induce turbulence models.
One of them (seems to be the best fit to my physical system) is:
Pfleger, D., and S. Becker. "Modelling and simulation of the dynamic flow behaviour in a bubble column." Chemical Engineering Science 56.4 (2001): 1737-1747.
The equation to add is the following:
G_{\alpha,BIT} = C_{k/\varepsilon} \mid M_{\alpha,\beta}\mid \cdot \mid u_\beta - u_\alpha\mid
The idea is:
1. calculate the work/energy done by each particle on the fluid
"The energy input of the bubble wakes results from the forces acting between a gas bubble and the surrounding liquid and the local slip velocity." as shown in the paper.
Therefore I added a field "Work" similar to the UTrans calculation
In Foam::KinematicParcel<ParcelType>::calcVelocity:
// note: Feff.Sp() and Fc.Sp() must be the same
dUTrans += dt*(Feff.Sp()*(Ures.average() - Uc_) - Fcp.Su());
// energy / work transported is needed for correct RANS simulation
dWork += (Ures.average() - Uc_) & dUTrans;
and
In Foam::KinematicParcel<ParcelType>::calc:
// Update momentum transfer coefficient
td.cloud().UCoeff()[cellI] += np0*Spu;
td.cloud().Work()[cellI] += np0*dWork;
2. Get this field and put it into the new kEpsilon Model by adding it to the "G" sourceterm:
volScalarField G(GName(),
    mut_*(tgradU() && dev(twoSymm(tgradU())))
    + C2_ * tWork //Line added from Pfleger Becker Equation
Well, thats my overall idea.... still many problems.
Has anyone done this in OpenFOAM before or has ideas, how this could be done properly?
Main problem at the moment is to get the "Work" field into my turbulence part...
Greetings
Andy
a.weber is offline   Reply With Quote
Old   July 27, 2015, 09:24
Andreas Weber
Update: Since the paper suggests to only take the drag-force into account, i will change to another solution:
I'm adding a drag vector to the particles variable list, which will allow me to also post-proccess the dragforce.
This list will then be used, to calculate my "work/energy" done to the fluid:
template<class CloudType>
inline const Foam::tmp<Foam::volScalarField>
Foam::KinematicCloud<CloudType>::work() const
    tmp<volScalarField> twork
        new volScalarField
            IOobject
                this->name() + ":work",
                this->db().time().timeName(),
                this->db(),
                IOobject::NO_READ,
                IOobject::NO_WRITE,
                false
            mesh_,
            dimensionedScalar("zero", dimPower, 0.0),
            zeroGradientFvPatchScalarField::typeName
    volScalarField& work = twork();
    forAllConstIter(typename KinematicCloud<CloudType>, *this, iter)
        const parcelType& p = iter();
        const label cellI = p.cell();
        work[cellI] += p.nParticle()*mag(p.U()-p.Uc() & p.drag());
    return twork;
hopefully, this will work soon.
Old   July 28, 2015, 11:03
Andreas Weber
ready!
Now I have it working. A Pfleger Becker K Epsilon Turbulence Model.
If anyone is interested, just leave a reply.
Old   July 30, 2015, 11:11
Andreas Weber
Hello again.
After some Testing, i found a little problem, when solving with mpirun.
The code runs without problems on a single node, but when it comes to multiprocessor runs I get an error.
As soon as the parcels are to be injected, my simulation will crash...only giving some default info:
[weber-VirtualBox:31670] *** An error occurred in MPI_Recv
[weber-VirtualBox:31670] *** on communicator MPI_COMM_WORLD
[weber-VirtualBox:31670] *** MPI_ERR_TRUNCATE: message truncated
[weber-VirtualBox:31670] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort
After some additional testing i found the problem sitting here:
void Foam::InjectionModel<CloudType>::postInjectCheck
    const label parcelsAdded,
    const scalar massAdded
    const label allParcelsAdded = returnReduce(parcelsAdded, sumOp<label>()); // <--- bug with mpirun
    if (allParcelsAdded > 0)
        Info<< nl
            << "--> Cloud: " << this->owner().name()
This is really confusing, because I didn't add anything to the code at this position. Still, it will always crash at this line. But why?
Does anyone know, what to do?
Old   October 5, 2016, 04:30
Werner
Polli is on a distinguished road
Hello Andi,
i have exactly the same problem like you with the injection problem in parallel.
Do you found any solution for the problem of the following error?
[weber-VirtualBox:31670] *** An error occurred in MPI_Recv [weber-VirtualBox:31670] *** on communicator MPI_COMM_WORLD [weber-VirtualBox:31670] *** MPI_ERR_TRUNCATE: message truncated [weber-VirtualBox:31670] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort
Polli is offline   Reply With Quote
Old   October 5, 2016, 08:49
Andreas Weber
jep, this error was resolved in http://bugs.openfoam.org/view.php?id=1556
Just look at the OpenFOAM-2.4/dev version, there everything is working:
https://github.com/OpenFOAM/OpenFOAM...PatchInjection
Cheers
Andy
Old   April 24, 2017, 11:17
surya kaundinya
suryakaundinya is on a distinguished road
I am currently trying to do the same thing and I have few questions. Did you add a new Parcel type or just made changes in Kinematic parcel directly and recompiled it? Because if you create a new parcel type the whole structure for the other parcel types has to be changed right?
With regards,
Surya
suryakaundinya is offline   Reply With Quote
Old   April 28, 2017, 04:46
Andreas Weber
I made a copy of src_intermediate and added the code to the kinematicParcel. Also made a copy of turbulenceModels and added stuff there.
Then just recompile with the modded src files.
Old   August 1, 2017, 05:46
surya kaundinya
Hello Andreas,
Can you please shed some light on how you called the "Work" field from the lagrangian model into the turbulence model.
Thanks and regards,
Surya.
Old   August 1, 2017, 11:52
Andreas Weber
andyyy123 is on a distinguished road
well, first add the function "work" like in my 1st post.
Then just initialize that as a field in the createClouds (or createFields):
work = parcels.work();
work.correctBoundaryConditions();
update this field after the lagrangian steps (in your main loop):
parcels.evolve();
That should enable to read it in your turbulence model (or simply from whereever you have mesh access):
const tmp<volScalarField> work_ = mesh_.lookupObject<volScalarField>("work");
This is all similar to "alpha" or "theta" found in KinematicCloudI.H
Best regards
Andreas
andyyy123 is offline   Reply With Quote
Old   August 8, 2017, 10:37
surya kaundinya
Thanks for the help. I did implement model as decribed above. But I have a small question (hope this will be the last one).
Did you define an initial condition for the source term seperately in 0/ folder during the simulation???
Surya.
Old   August 8, 2017, 10:39
Andreas Weber
its set to uniform 0 at the start of every time step since you only want to have the work from the current step in your source.
Old   August 8, 2017, 10:53
surya kaundinya
Looks like I did something wrong. The simulation requires me to give an initial condition for this term.
Old   August 8, 2017, 10:59
Andreas Weber
if I call parcel.work(), a temp field is created with values uniform 0.
        new volScalarField
            IOobject
                this->db(),
                IOobject::NO_READ,
                IOobject::NO_WRITE,
                false
            mesh_,
            dimensionedScalar("zero", dimPower/dimVol, 0.0),
also in my createField is use an empty field with NO_READ option
    volScalarField work
        IOobject
            "work",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        mesh,
that should not ask for an initial condition
Old   August 8, 2017, 11:12
surya kaundinya
I did the same thing, but in the createFields.H I forgot to include
It's working now.
And one last clarification : Did you calculate the drag vector term directly in KinematicParcel.C from the SuSp and velocity terms?
Old   August 9, 2017, 03:46
Andreas Weber
hmm not really....
unfortunately all coupled forces are summed up there.
so i save only the drag in an additional parcel property... (you could just take the "user" property for testing purpose)
i'm sure there is a better solution.... but this is what came to my mind at first
e.g. in breakup calculation
(void Foam::SprayParcel<ParcelType>::calcBreakup)
there may be a snippet of code you can use since there the "tmom" is calculated with forces:
const forceSuSp Fcp = forces.calcCoupled(p, dt, mass, Re, muAv);
const forceSuSp Fncp = forces.calcNonCoupled(p, dt, mass, Re, muAv);
this->tMom() = mass/(Fcp.Sp() + Fncp.Sp());
downside is!!! all forces are recalculated in this step (i don't know if it is better in v3.x or v4.x, i'm using v2.4)
Old   August 9, 2017, 06:17
surya kaundinya
I did something similar. I created a function similar to calcVelocity, where I recalculated the forces.Later I used this function to calculate the drag force vector.
this->dragForce_= calcDrag(td, dt, cellI, Re, muc_, mass0);
Thanks for the inputs.
Surya.
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 16:14
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
