phi == pEqn.flux() rhoSimpleFoam
Old   July 9, 2015, 11:10
Question phi == pEqn.flux() rhoSimpleFoam
België/Belgique
David1 is on a distinguished road
Does anyone know why for the transonic case in rhoSimpleFoam the flux is calculated as:
phi == pEqn.flux(); ?
If transonic is turned off, then the flux is calculated in the 'normal' way, i.e. first calculting the flux without the contribution of the pressure gradient:
phi = fvc::interpolate(rho)*(fvc::interpolate(U) & mesh.Sf() )
And after the calulation of the pressure, the old flux value gets corrected using the new pressure:
phi -= pEqn.flux();
So I do not understand why the flux in the transonic case is not calculated as:
phi == fvc::interpolate(rho)*(fvc::interpolate(U) & mesh.Sf() ) - pEqn.flux()
as well.
I hope somebody can help me with this.
Thank you in advance!
David1 is offline   Reply With Quote
flux, peqn, phi, rhosimplefoam, transonic
phi -= pEqn.flux() vs. linearInterpolate(U) & mesh.Sf() santiagomarquezd OpenFOAM Programming & Development 33 October 15, 2019 11:24
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
pEqn.flux() cheng1988sjtu OpenFOAM Running, Solving & CFD 4 November 21, 2012 16:08
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls david39 OpenFOAM Running, Solving & CFD 6 January 18, 2011 12:49
Turbulence Model phi vs phi_ doug OpenFOAM Running, Solving & CFD 4 November 10, 2009 05:33
