June 30, 2015, 12:53 |
buoyantPimpleFoam's equations.
Dongyue Li
Rep Power: 18 |
Hello guys,
Right now Im working on buoyant driven force flow. I have a miner confusion about the equations implemented in buoyantPimpleFoam. We know that: rho1 = rho0 + psi*(p1-p0) = rho0 + psi*(p_rgh1 - p_rgh0 + rho1 g h - rho0 g h) // neglected? But in the code, it is: rho1 = rho0 + psi*(p_rgh1 - p_rgh0) Code:
fvScalarMatrix p_rghDDtEqn ( fvc::ddt(rho) + psi*correction(fvm::ddt(p_rgh)) + fvc::div(phiHbyA) == fvOptions(psi, p_rgh, rho.name()) ); Thanks Update: Its neglected. more info: http://www.openfoam.org/mantisbt/view.php?id=1772#c5033
My OpenFOAM algorithm website: http://dyfluid.com By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html Last edited by sharonyue; July 2, 2015 at 11:42. |
September 11, 2019, 12:29 |
Another question on buoyantPimpeFoam's pEqn
Jost Kemper
Rep Power: 8 |
Hi All,
I realize this thread is a bit old and the issue seems to be resolved by now. However, I have a much related question and since the title of the thread is kept quite broad I hope its okay to post this here: I'm having trouble understanding what buoyantPimpleFoam's pEqn does with the reference pressure (pRef) in an incompressible case. The pressure equation is solved setting a reference pressure for p_rgh: Code:
p_rghEqn.setReference ( pRefCell, compressible ? getRefCellValue(p_rgh, pRefCell) : pRefValue ); This is in line with standard pimpleFoam for the incompressible case. (okay so far) But then, after caculating p from p_rgh... Code:
p = p_rgh + rho*gh; ...they go ahead and change p again (if the reference pressure is used) Code:
if (p_rgh.needReference()) { if (!compressible) { p += dimensionedScalar ( "p", p.dimensions(), pRefValue - getRefCellValue(p, pRefCell) ); } else { p += (initialMass - fvc::domainIntegrate(psi*p)) /compressibility; thermo.correctRho(psi*p - psip0); rho = thermo.rho(); p_rgh = p - rho*gh; } } else { thermo.correctRho(psi*p - psip0); } Why do they do that? Is pRef meant to be a reference value for p or for p_rgh now? How can they accept, that p is inconsistent with p_rgh (in the sense that p != p_rgh + rho*gh)? And if that's fine, why did they choose a different path for bouyantSimpeFoam, where they do "p_rgh = p - rho*gh;" afterwards? I would really appreciate if somebody could explain this to me. Cheers, Jost |
Guide: Writing Equations in LaTeX on the CFD Online Forums | pete | Site Help, Feedback & Discussions | 27 | May 19, 2022 04:19 |
how to implement k-epsilon equations in ADI method | kiamey | Main CFD Forum | 2 | July 17, 2014 18:13 |
modelling Differential equations in a udf | RikardMNorén | Fluent UDF and Scheme Programming | 2 | October 1, 2013 04:36 |
Riemann invariants of adjoint equations of shallow water equations | zqb0929 | Main CFD Forum | 0 | March 15, 2012 01:54 |
CFD governing equations | m.gos | Main CFD Forum | 0 | April 30, 2011 15:21 |
