Species transport in Darcy flow
Old   June 29, 2015, 04:15
Default Species transport in Darcy flow
Yan Wang
wayne14 is on a distinguished road
Hi everyone,
I am trying to solve a species transport problem in darcy flow. Both viscosity and density depend on the species concentrations.
The equations and my calculation procedure are attached.
My test case is a point leakage at the location (0,0,0). I will post the case and solver here.
Hope you can help me.
Regards,
Wayne
wayne14 is offline   Reply With Quote
Old   June 29, 2015, 04:45
Yan Wang
This is the solver and the two test case.
In test case Exo72D2Q0, the source strength is set to 0.
In this case, the air should just pile up without any movement.
The boundary conditions for pressure p seems to be ok now as follows:
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 101.325e3;
boundaryField
    frontandback
        type empty;
    walls
        type            zeroGradient;
    up
        type            fixedValue;
        value           uniform 101.325e3;
    down
       type groovyBC;
       variables "gradp=Rho*9.81;";
       gradientExpression "gradp";
       value uniform 101361.69921;
       fractionExpression "0";
Old   June 29, 2015, 05:01
Unhappy
Yan Wang
In test case Exo72D2, the source strength for CH4 is
Q Q [1 0 -1 0 0 0 0] 1.48e-5;// kg/s
This time the p still converge very fast, but the concentration (kg/kg) of CH4, 'TS2', would not converge below e-3
The concentration (kg/kg) of CH4 is shown in TS2.jpg and TS2 bigger.jpg.
The biggest problem is that TS2 does not meet the mass balance! Will someone be interested in helping me?
Old   June 29, 2015, 11:53
Yan Wang
It seems that the problem have been solved after I correct the boundary conditions. However, I still wish that you can comment on my solver so that I can develop a better one in the future.
Old   September 26, 2016, 03:06
Patrick Kastner
kostnermo is on a distinguished road
Hi Yan,
could you tell me how you corrected the BCs?
I am trying to solve a similar problem at the moment.
Kind regards,
Patrick
kostnermo is offline   Reply With Quote
Old   September 26, 2016, 05:12
Yan Wang
Originally Posted by kostnermo View Post
Hi Yan,
Kind regards,
Patrick
Hi Patrick,
I will email you.
Regards,
Yan
darcy flow, density-variable, species transport, viscosity
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Species transport in multiphase flow Dinar FLUENT 7 December 3, 2016 13:46
Species transport simulation in cyclic flow SH_P FLUENT 0 May 29, 2015 12:15
species transport in water lyn FLUENT 1 December 12, 2007 19:15
Graphical image of a species flow Rajeev Kumar Singh FLUENT 1 September 23, 2001 05:10
