Actuator Disk Implementation Problem
Old   June 26, 2015, 05:47
Default Actuator Disk Implementation Problem
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hello Foamers,
I am learning OpenFOAM for my PhD. I will be doing wake effect analysis of the shrouded wind turbine by using actuator disc model. I just found a good paper that explains the implementations of an actuator disk in OpenFoam (See the links below).
http://www.tfd.chalmers.se/~hani/kur...ningReport.pdf
Furthermore, I found the actuator disk example (attached below) by the same author Erik Svenning posted in upper link, and it was made in version 1.5. I am currently using version 2.3.2. Moreover, I have been able to run blockMesh successfully, however, I can't view the mesh in paraFoam. And I get errors when trying to run simpleFoam of the example.
I am asking if anybody of you could find some time to explain what is exactly wrong with version 2.3.2.
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for cyclic fan_half0
Is your field uptodate with split cyclics?
Run foamUpgradeCyclics to convert mesh and fields to split cyclics.
file: /home/tariq/windturbine/project3/erikSvenningFiles/fan/0/p.boundaryField from line 34 to line 59.
From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&)
in file /home/tariq/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 192.
FOAM exiting
Thanks in advance
fan.zip
tareqkh is offline   Reply With Quote
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 08:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
k epsilon model implementation problem jyothishkumar Main CFD Forum 0 July 19, 2011 10:39
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
