How to Specify a Fixed Volume Charge Density?
Old   June 25, 2015, 20:43
Default How to Specify a Fixed Volume Charge Density?
Cory
cgerrity is on a distinguished road
What is the best way to define a *fixed* space (volume) charge density in OpenFOAM? The electrostaticFoam source code appears to use the continuity equation (in bold), implying rho is not fixed in space:
Description
    Solver for electrostatics.
#include "fvCFD.H"
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    #include "createFields.H"
    Info<< "\nStarting iteration loop\n" << endl;
    while (runTime.loop())
        Info<< "Iteration = " << runTime.timeName() << nl << endl;
        solve
            fvm::laplacian(phi) + rho/epsilon0
        rhoFlux = -k*mesh.magSf()*fvc::snGrad(phi);
        solve
            fvm::ddt(rho) + fvm::div(rhoFlux, rho)
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    Info<< "End\n" << endl;
    return 0;
cgerrity is offline   Reply With Quote
Old   June 29, 2015, 18:24
Cory
I was able to do this by copying and modying the electrostatics solver directly. The trick is to specify the charge density for every part of the mesh by looping through it and then running the solver. If you want fixed space charge, make sure your solver doesn't change rho.
Old   September 16, 2020, 17:10
Cody
cjessup37 is on a distinguished road
Hi Cory,
I am new to C++ coding and OpenFOAM. What do you mean 'specifying the charge density for every part of the mesh by looping through it'? Could you possibly share your code?
For context, I am trying to use electrostaticFoam as a way to calculate the gravitational field (little g) of a mass(es). I have changed the epsilon constant to what it needs to be for gravity as well as the units of phi and rho. I am having trouble specifying rho. I still need to change the solver to include the little g calculation but that looks straightforward based on what I read in the OpenFoam user guide.
Thanks!
Cody
cjessup37 is offline   Reply With Quote
charge density, electrostatic, electrostaticfoam, space charge, volume charge density
Problem regarding high density ratio(1:1000) in volume of fluid(VOF) method j.patel Main CFD Forum 0 September 17, 2013 06:25
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
Error in adjusting mesh volume density in ICEM? Shab CFX 0 October 31, 2007 08:24
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
