How i can equal a new variable with a PDE
Old   June 23, 2015, 05:21
Question How i can equal a new variable with a PDE
Hesam
rapierrz is on a distinguished road
Hi friends,
I want to equal a variable with a pde :
U is calculated from navier stokes equation and I want to have :
a=ddt(U)+div(phi.U)-g;
How I can define this equation in openfoam solver???
rapierrz is offline   Reply With Quote
Old   June 23, 2015, 06:33
chriss85 will become famous soon enough
First you need to define your new variable. This is usually done in createFields.H in the solver.
Then you will have to assign it. You're not solving a PDE here, you're just assigning a value. For this you want to use the explicit schemes, namely
a = fvc::ddt(U) + fvc::div(phi, U) - g;
chriss85 is offline   Reply With Quote
Old   June 23, 2015, 07:16
Hesam
Thank u very much Chriss,
I have another question.
How I can solve equation x*mag(x)=a that x is a vector and a is the
same a=fvc::ddt(U)+fvc::div(U)-g
Old   June 23, 2015, 07:26
Can't you just rewrite that to x=sqrt(mag(a))*sign(a) ?
Edit: Nevermind, I skipped the vector part. So you're coupling between the vector components by using the magnitude? I think you might have to use a fixed point procedure then, such as Newton's method
Old   June 23, 2015, 07:51
Hesam
thank you friend,
my target is that calculate the drift velocity then use it in navier stokes
equations but in my equation there is V*mag(V)=a and V is relative velocity
How I can solve V?what is initial guess for V in createField?
thank u
Old   June 23, 2015, 08:04
You don't have a differential equation there but a normal equation that you need to invert numerically. Please read up and see if Newton's method (or some similar iterative method) is suitable for this. Equation solving capability of OpenFOAM is not going to help you here, you will have to program this yourself.
Old   June 23, 2015, 08:18
Hesam
Thank u chriss,
I will search about it.
using time as a variable to classify a pde nargess_md Main CFD Forum 9 October 6, 2013 06:38
emag beta feature: charge density charlotte CFX 4 March 22, 2011 10:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 05:35
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
