Use "std::vector<double>" in a openfoam code
Old   June 22, 2015, 12:39
Default Use "std::vector<double>" in a openfoam code
sidworks is on a distinguished road
I have a utility which compiles and runs fine. But, I wish to make a few changes in it. In order to do that I want to use the standard c++ vectors as I am not very familiar with the OpenFOAM architecture. So the code looks like,
#include<vector>
std::vector<double> abc;
I am getting the following error message when I try to compile it using "wmake". I am not sure what's going wrong here. Any help will be appreciated!
Making dependency list for source file perturbU.C
SOURCE=perturbU.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/siddhesh/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/home/siddhesh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/siddhesh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/siddhesh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/perturbU.o
perturbU.C: In function ‘int main(int, char**)’:
perturbU.C:220:2: error: ‘vector’ is not a member of ‘std’
perturbU.C:220:2: note: suggested alternatives:
In file included from /home/siddhesh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude/point.H:35:0,
from /home/siddhesh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude/pointField.H:35,
from /home/siddhesh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude/edge.H:40,
from /home/siddhesh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude/edgeList.H:32,
from /home/siddhesh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude/primitiveMesh.H:54,
from /home/siddhesh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude/polyMesh.H:45,
from /home/siddhesh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMesh.H:50,
from /home/siddhesh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvCFD.H:7,
from perturbU.C:40:
/home/siddhesh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude/vector.H:49:24: note: ‘Foam::vector’
typedef Vector<scalar> vector;
perturbU.C:220:14: error: expected primary-expression before ‘double’
perturbU.C:220:14: error: expected ‘;’ before ‘double’
perturbU.C:217:9: warning: unused variable ‘zcoordinate’ [-Wunused-variable]
double zcoordinate = (cCentre & zDir);
perturbU.C:218:9: warning: unused variable ‘ycoordinate’ [-Wunused-variable]
double ycoordinate = yw[celli];
make: *** [Make/linux64GccDPOpt/perturbU.o] Error 1
sidworks is offline   Reply With Quote
Old   August 10, 2023, 06:33
parsaest is on a distinguished road
I know it has been a while and i hope your problem has been resolved. But just to have this as a tip, I think it might be because you haven't declared vector (#include <vector>) in the main solver file ie. icofoam.C
parsaest is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
Memory protection in OpenFOAM / combinig with FORTRAN botp OpenFOAM Programming & Development 2 February 15, 2016 13:25
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 08:18
How to code integral of (DU/Dt - 2000 ) in openFoam erncyc OpenFOAM 5 September 13, 2012 07:33
OpenFOAM for subsurface flow, or coupling with a subsurface flow code? chljl OpenFOAM Running, Solving & CFD 0 February 14, 2012 20:38
