lookup-tables
Old   June 19, 2015, 10:58
Exclamation lookup-tables
Gert-Jan Meijn
GJM1991 is on a distinguished road
Hi everybody,
Can somebody give me a start on some information to create a new thermodynamic model that is based on lookup-tables?
Currently I have a barotropic relation that in itself is too complex to implement inside OpenFoam but eventually is a barotropic relation.
This means that I have values of pressure corresponding to a certain density of the fluid.
So if I have a density-field I want to use the lookup-table to obtain the pressure for the entire field.
I am still figuring out what to do with other calls that can be found in a thermodynamic model like speed of sound or compressibility.
Can somebody help me with this? Does anybody have examples on how to do this? Your help is much appreciated!
GJM1991 is offline   Reply With Quote
Old   January 19, 2018, 07:30
Ahmed Shoeb
Ahmedshoeb is on a distinguished road
I am currently dealing with a similar issue, I am trying to read the density values from a Pressure and Tempreture lookup table.
Have you been able to solve this problem.
Any help would be appritiated
Ahmedshoeb is offline   Reply With Quote
Old   February 27, 2018, 11:46
Chunkan Yu
antonyu1221 is on a distinguished road
I am also facing with such problems. What I am thinking now, is to modify the psi, because rho and p are coupled with psi. Psi can be calculated through my lookup table.
But I am still struggling with how to do that...
antonyu1221 is offline   Reply With Quote
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 21:47
FlameletFoam tables and OpenFOAM-2.3.x Look-Up-Tables Sermengi OpenFOAM 2 December 19, 2014 07:10
Convergence on anisotropic tetahedral meshes pbo OpenFOAM Running, Solving & CFD 12 December 14, 2010 12:59
Error with 'vanAlbada' scheme Julian K. OpenFOAM Running, Solving & CFD 0 June 18, 2009 10:31
Buoyancydriven cavity flow anita OpenFOAM Running, Solving & CFD 3 March 26, 2008 11:24
