Changing some variables at scalarCodedsource without direct contact with openfoam
Old   June 12, 2015, 12:11
Default Changing some variables at scalarCodedsource without direct contact with openfoam
Mehdi Asghari
Asghari_M is on a distinguished road
Hello everyone!
There is a transient heat source in my problem according to the following relation:
S(heat)=N × sqrt(t) ;
That t is time and N is an integer multiplier.
I can use the following code in the heat source term definition indicated at scalarCodedSource in fvOptions only for one multiplier (for example N=1):
N=1;
heSource -= N* sqrt(time.value())*V;
However, I want to do 30 runs for a geometry case. Every run is corresponding to one n.
Really, multiplier (N) Varies from one to 30.After the simulation has ended, the data of the last time-step is saved to a separate directory. Similar task has been described for inlet velocity at following link by PyFoam (and in 2.2 parameter variation):
https://openfoamwiki.net/index.php/Contrib/PyFoam ------->2.2parameter variation
In the other words, I want to vary source term value without direct contact with OpenFoam2.3.1 in a loop structure. How can I do this operation?
Thanks in advance for any help.
Asghari_M is offline   Reply With Quote
heat source term, parameter variation, scalarcodedsource
Can OpenFOAM simulate rubber flow when changing from its solid to liquid phase? sur4j OpenFOAM 0 September 21, 2013 07:05
[swak4Foam] a script for changing variables in groovyBC in 0 folder immortality OpenFOAM Community Contributions 38 July 22, 2013 18:57
[OpenFOAM.org] Changing $ParaView_DIR for use with multiple OpenFOAM versions Razman OpenFOAM Installation 0 September 17, 2012 10:45
Changing contact line tfe FLOW-3D 3 December 8, 2009 03:59
changing variables in any iteration using udfs Asghari FLUENT 2 August 11, 2006 10:06
