Dymanic load balancing in dynamicRefineFvMesh |
May 28, 2015, 07:36 |
Greetings, dear FOAM'ers.
Does anyone know, is there available version of dynamicRefineFvMesh with dynamic load balancing? As far as I understood, dynamic load balancing works in dynamicTopoFvMesh. However, I have a case with purely hexahedral mesh where the AMR model used in dynamicTopoFvMesh is not applicable. Best regards! |
May 28, 2015, 08:17 |
Sorry, I didn't notice this:
http://www.cfd-online.com/Forums/ope...balancing.html I'll try to port this lib to foam-extend since I'm get used to foam-extend branch. |
January 4, 2016, 10:08 |
#3 | |
Hua
Rep Power: 14 |
Did you succeed to port this lib to foam-extend? I am using foam-extend 3.0 too and want to use dynamic load-balance in refinement procedure. Would you please give me some suggession? |
January 29, 2016, 18:29 |
Ripudaman Manchanda
Rep Power: 13 |
I am interested in using this with the latest version of foam-extend-3.2. Does anyone have a port for this yet?
Thank you. Ripu |
amr, dynamic load balancing |
Run-Time Parallel Load Balancing | tgvosk | OpenFOAM Programming & Development | 25 | December 4, 2024 04:51 |
[Other] Load balancing with dynamic mesh | tikulju | OpenFOAM Meshing & Mesh Conversion | 12 | May 26, 2017 00:04 |
Proper Load balancing in OF | Tarak | OpenFOAM | 3 | February 19, 2011 07:41 |
load balancing in parallel computation | shyamdsundar | Main CFD Forum | 0 | September 3, 2009 00:53 |
Hanging node grid + load balancing in parallel??? | Phil | FLUENT | 0 | February 15, 2008 09:38 |
