Custom wall function problem
Old   May 21, 2015, 09:12
Default Custom wall function problem
Kairzhan
kairzhan is on a distinguished road
Hi Foamers !
I'm trying to implement my turbulence model, and stuck with wall-function for k. I need to specify a value for k on the boundary which is calculated from other variables. So to do this I copied the standard wall-funcion definition from epsilon (epsilonWallFunction) which does the needed functionality but for different variable (epsilon). So I renamed class and all it's methods from epsilon to k. Everything compiled normally. But when I tried to specify new wall-funcions for k I got runtime error message:
Unknown pathField type kBuoyantWallFunction for patch type wall...
And my wall function is not listed in valid patch field types.
However, if I try to specify this same wall-function name ( kBuoyantWallFunction) for epsilon it finds it, as valid wall-function but for wrong variable.
So it seems that my wall function is registered in the wrong selection table..
How can I specify where the wall function should be registered ?
The code is in attachments.
kairzhan is offline   Reply With Quote
Old   June 1, 2015, 12:15
Patrick Grover
Patrick Grover is on a distinguished road
Hi
I am also working on custom wall functions for OpenFoam.
I your controlDict file do you link to your custom library? This is what I have added at the bottom of my controlDict file:
<code>
libs
"libmyIncompressibleRASModels.so"
</code>
Cheers,
Patrick
Patrick Grover is offline   Reply With Quote
Old   June 2, 2015, 06:45
Default Solved
Kairzhan
Hi Patrick,
Thank you for the reply, but I've finally managed applying custom WF. The problem was in that I didn't commented k_.boundaryField().types() from the kEpsilon.C file:
tmp<volSymmTensorField> kEpsilon::R() const
    return tmp<volSymmTensorField>
        new volSymmTensorField
            IOobject
                "R",
                runTime_.timeName(),
                mesh_,
                IOobject::NO_READ,
                IOobject::NO_WRITE
            ((2.0/3.0)*I)*k_ - nut_*twoSymm(fvc::grad(U_)),
It seems that k_.boundaryField().types() somehow affects the visibility of custom WF.
openfoam, turbulence, wall functions
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[mesh manipulation] mergeMeshes problem Attesz OpenFOAM Meshing & Mesh Conversion 3 July 29, 2015 05:15
Problem creating a new Wallfunction on OF 2.2 ! fredo490 OpenFOAM Programming & Development 8 July 22, 2014 06:16
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
Wall function in adverse pressure gradients stephane baralon Main CFD Forum 11 September 2, 1999 05:05
