Assigning time dependent heat Source terms
Like Tree3Likes
Old   August 1, 2015, 15:40
Hassan Kassem
hk318i is on a distinguished road
You are right, usually I check the source code to get a definitive answer. Additionally, some code testing could be needed to better understand how certain parts of OF really works.
hk318i is offline   Reply With Quote
Old   August 2, 2015, 01:50
Mehdi Asghari
Asghari_M is on a distinguished road
Hi.
I prefer to trace/search the part of main program of OF recalling hesource at following scalarCodedSource code:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvOptions;
energySource
type            scalarCodedSource;
    active          true;
    selectionMode   all;
    scalarCodedSourceCoeffs
        fieldNames      (h);
        redirectType    sourceTime;
        codeInclude
        codeCorrect
            Pout<< "**codeCorrect**" << endl;
        codeAddSup
            const Time& time = mesh().time();
            const scalarField& V = mesh_.V();
            const vectorField& C = mesh_.C();
             // How & where (which sub-program) does main program (source code) read/recall hesource?//
            scalarField& heSource = eqn.source();
            scalar hs = (2.0*time.value())/(1+time.value());
//   heSource +=  hs
              .OR.
     heSource +=  hs*V;//
    Pout << "***codeAddSup***" << endl;
        codeSetValue
            Pout<< "**codeSetValue**" << endl;
        // Dummy entry. Make dependent on above to trigger recompilation
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
    sourceTimeCoeffs
        // Dummy entry
Can u help me in how to find hesource in main program? In other words, how& where does main program use hesource as output of scalarCodedSource? How is the hesource transferred within subroutines?
I'd appreciated for any help.
Asghari_M is offline   Reply With Quote
Old   August 2, 2015, 10:06
Hassan Kassem
Tomislav Maric post about fvOptions is very good starting point to understand how fvOptions works. [LINK].
I can confirm two points here, first the source term "he" should have units of Watts [Kg m2 S-3]. Secondary the heSource should be (heSource-= hs) or (he = -hs) too act as source otherwise it will act as sink. I think that could explain the drop in Temperature in your case.
Old   August 2, 2015, 16:23
Smile
  #24
Mehdi Asghari
Hello Hassan.
I conclude the correct scalarCodedSource type of fvOptions for my heat source is based on ur points as follows:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvOptions;
energySource
    active          true;
    selectionMode   all;
        fieldNames      (h);
        codeInclude
        codeCorrect
        codeAddSup
     // the correct relation for hesource is presented as follows: //
  heSource -=  hs*V;//Isn't it?//
        codeSetValue
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
    sourceTimeCoeffs
        // Dummy entry
Thanks a lot for your all helpful answers during this thread.
M.Asghari
Old   August 2, 2015, 16:35
Hassan Kassem
Yes, it looks good. Give it a try and see the results. Please keep us updated.
Best wishes,
Hassan
@HIKassem | HassanKassem.me
Old   August 3, 2015, 01:19
Mehdi Asghari
conclusion:
Really, since my heat source term is specific and scalarCodedsource returns absolute value as heSource (in watt unit), user should use *V notation (multiplying hesource by mesh volume) for scalarCodedSource type in fvOptions.
Best Wishes
SHUBHAM9595 likes this.
Transient spacial dependent heat source Kumudu OpenFOAM Running, Solving & CFD 0 October 28, 2013 12:02
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
