mesh.V() does not work inside stochasticDispersion member function
Old   May 17, 2015, 19:46
Default mesh.V() does not work inside stochasticDispersion member function
Gustavo
ghindi is on a distinguished road
Hi Foamers.
I'm currently trying to modify the stochasticDispersion.C code, that is part of spraySubModel.
Basically I'm modifying the member function disperseParcels().
In the method that I'm changing I need the cell dimension. As I'm using hexahedral elements I just need to read the cell volumes and obtain the cubic root. I'm trying to use mesh.V() to get the cell volumes but when I try to compile the library (wmake libso) I get errors.
The line in the code is
scalar xDim = Foam:: pow(mesh.V()[celli],1/3);
The compilation error message is below:
error: ‘mesh’ was not declared in this scope
If then try the following,
scalar xDim = Foam:: pow(fvMesh::V()[celli],1/3);
error: cannot call member function ‘const Foam:: DimensionedField<double, Foam::volMesh>& Foam::fvMesh::V() const’ without object
Does anyone knows how to solve that?
Thanks a lot for any assistance.
Regards,
Gustavo.
ghindi is offline   Reply With Quote
Old   May 18, 2015, 04:40
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
There is no mesh in spraySubModels, but there is spray_ [1] member, which has mesh method [2], so your "mesh.V()" should be "spray_.mesh().V()".
1. https://sourceforge.net/p/openfoam-e...ionModel.H#l57
2. https://sourceforge.net/p/openfoam-e...y/spray.H#l246
alexeym is offline   Reply With Quote
Old   May 18, 2015, 21:59
Gustavo
Thanks Alexey it worked.
Regards,
Gustavo.
cell volume, libso member function, mesh.v()
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 11:20
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
