Error in running case in chtMultiRegionFoam
Old   May 15, 2015, 02:49
Default Error in running case in chtMultiRegionFoam
baran
baran_foam is on a distinguished road
Greeting all!!!
I want to use the chtMultiRegionFoam for a geometry of air surrounding with solid.
When i was trying to run this case I got the following error .....
Create time
Create fluid mesh for region fluid_air for time = 0
Create solid mesh for region solid_insu for time = 0
*** Reading fluid mesh thermophysical properties for region fluid_air
Adding to thermoFluid
Selecting thermodynamics package hRhoThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
Adding to rhoFluid
Adding to kappaFluid
Adding to UFluid
Adding to phiFluid
Adding to gFluid
Adding to turbulence
Selecting turbulence model type RASModel
Selecting RAS turbulence model kOmegaSST
kOmegaSSTCoeffs
alphaK1 0.85034;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.85616;
Prt 1;
gamma1 0.5532;
gamma2 0.4403;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
c1 10;
Adding to ghFluid
Adding to ghfFluid
Selecting radiationModel viewFactor
Selecting absorptionEmissionModel constantAbsorptionEmission
Selecting scatterModel constantScatter
Total number of clusters : 115
Insert elements in the matrix...
Smoothing the matrix...
Adding to KFluid
Adding to dpdtFluid
*** Reading solid mesh thermophysical properties for region solid_insu
Adding to thermos
Constructed constSolidThermo with
rho : rho [1 -3 0 0 0 0 0] 8000
Cp : Cp [0 2 -2 -1 0 0 0] 450
K : K [1 1 -3 -1 0 0 0] 80
Hf : Hf [0 2 -2 0 0 0 0] 0
emissivity : emissivity [0 0 0 0 0 0 0] 0.7
kappa : kappa [0 -1 0 0 0 0 0] 0
sigmaS : sigmaS [0 -1 0 0 0 0 0] 0
Region: fluid_air Courant Number mean: 1.61574e-05 max: 8e-05
Region: solid_insu Diffusion Number mean: 4.7133365e-07 max: 1.7777782e-06
Time = 0.0001
Solving for fluid region fluid_air
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/apps/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/apps/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
at sigaction.c:0
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/apps/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam:perator/(Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/apps/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 Foam::diagonalSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/apps/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/apps/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#7 Foam::fvMatrix<double>::solve() in "/opt/apps/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/chtMultiRegionFoam"
#9 __libc_start_main in "/lib64/libc.so.6"
Can anyone kindly mention exactly where I have done the mistake??
Thanks in advance
regards,
baran
baran_foam is offline   Reply With Quote
Old   June 2, 2015, 03:03
Unhappy Problem in high temperature boundary condition in chtMultiregionFOAM
baran
Hello ,
greeting all!!!
I have some simple geometry as mentioned above.Now i want to implement this in openfoam-2.4.0.
Some details are as follows...
geometry- cavity, surrounding this cavity solid, some heating element in cavity
turbulence model- k epsilon
radiation model- viewfactor
boundary condition- constant T (1. 400 K ,2. 600 K)
In the first case of 400 K it works well,but in 600K or higher temperature it diverges after one iteration.....
Can some one please clarify where is the exact problem in my case?
For better understaanding of the problem...I have attached my case file...so please clarify how I resolve my problem??
I have really facing trouble in this...
please help...
https://www.dropbox.com/s/egyyc1vt7tqq1a1/box.rar?dl=0
Regards,
baran
Old   July 6, 2015, 11:50
coccone is on a distinguished road
at sigaction.c:0
It appears as if you divided something by zero... this could also depend on your mesh (at least I saw this kind of error with mine). Did you run a checkMesh to see if you have issues with some cells?
PS:use [/CODE] tags instead of [/QUOTE]
coccone is offline   Reply With Quote
Old   July 7, 2015, 05:38
baran
Greeting all!
@cocone...In the mesh there is no problem...I have some initial condition issue mostly and it create high Courant no ..but I have sort it out...
Regards,
baran
Large test case for running OpenFoam in parallel fhy OpenFOAM Running, Solving & CFD 23 April 6, 2019 10:55
Problem for parallel running chtMultiregionFoam Giancarlo_IngChimico OpenFOAM Programming & Development 4 December 21, 2016 04:26
chtMultiRegionFoam running in parallel sparbroetchen OpenFOAM Running, Solving & CFD 1 July 30, 2012 04:10
chtMultiRegionFoam case - temperature too high phsieh2005 OpenFOAM Running, Solving & CFD 0 April 24, 2010 09:53
I have a Problem to create new Case lange OpenFOAM Pre-Processing 1 June 24, 2005 16:41
