Non- stop running for a time-dependent heat source problem
Old   May 8, 2015, 12:32
Default Non- stop running for a time-dependent heat source problem
Mehdi Asghari
Asghari_M is on a distinguished road
Hello All;
I want to solve a heat conduction problem with time-dependent heat source term in OpenFoam.
I need to obtain the temperature field for final time (Tf=10s), only. Also, there is a time-dependent source term in this problem as follows:
S(t)= a j t; wherein a= 12.5 , j is an integer number.Moreover I’d like to get the results for j={1,2,…,50}. I need only to save the temperature field for final time ( Tf=10s). My questions are presented as follows:
1-Is it possible to be saved the temperature field for all j(one directory for every j) only in a 10.0 directory as final time directory in running process in a Non-stop manner (for example in a loop) (also, I don’t need results for other times)?
2- How can I define time-dependent heat source term according to the above mentioned relation for S(t) by fvOptions in OpenFoam 2.3.1?
Cheers,
Asghari_M is offline   Reply With Quote
Old   May 11, 2015, 06:13
Question
Mehdi Asghari
Ohh!
Unfortunately, I wrote a simple fvOptions and faced some errors!
FoamFile
   version     2.0;
   format      ascii;
   class       dictionary;
   location    "system";
   object      fvOptions;
energySource
   type            scalarSemiImplicitSource;
   active          true;
   selectionMode   all;
s0=1e4;
   scalarSemiImplicitSourceCoeffs
       volumeMode      specific;
       injectionRateSuSp
           h           (s0 0);
With following strange error!!
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 30 the word 's0'
file: /home/scientist/OpenFOAM/scientist-2.3.1/run/tutorials/heatTransfer/heatconductionFoam/heatconduction/system/fvOptions.energySource.scalarSemiImplicitSourceCoeffs.injectionRateSuSp.h at line 30.
   From function operator>>(Istream&, Scalar&)
   in file lnInclude/Scalar.C at line 93.
FOAM exiting
How can I define a non-constant scalar or time-dependent for injectionRateSuSp at fvOptions?
I'd be appreciated for any help.
non-stop running
Adding heat source to chtMultiRegionFoam maddalena OpenFOAM Programming & Development 61 February 17, 2018 09:33
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
time dependent source using DEFINE_SOURCE T81 Fluent UDF and Scheme Programming 5 February 28, 2011 18:23
