Declaring volScalarField in viscosityModel
Old   May 8, 2015, 10:50
Default Declaring volScalarField in viscosityModel
zbtlfd is on a distinguished road
Dear All,
I've been trying to implement a new volScalarField for the kinematic viscosity into the Herschel-Bulkley viscosity model. So far I've tried a few versions of initialising it and they have compiled without errors. However, the solver always crashes, when the "calcNu()" function tries to return the newly implemented viscosity field without even manipulating it (just as a test case for now). The error message is always as follows:
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model HerschelBulkley
test1
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
 at sigaction.c:?
#3  Foam::List<double>::List(Foam::List<double> const&) at ??:?
#4  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5  Foam::viscosityModels::HerschelBulkley::HerschelBulkley(Foam::word const&, Foam::dictionary const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#6  Foam::viscosityModel::adddictionaryConstructorToTable<Foam::viscosityModels::HerschelBulkley>::New(Foam::word const&, Foam::dictionary const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#7  Foam::viscosityModel::New(Foam::word const&, Foam::dictionary const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#8  Foam::singlePhaseTransportModel::singlePhaseTransportModel(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
 at ??:?
#10  __libc_start_main at ??:?
#11
 at ??:?
In the HerschelBulkley.H file, I've declared the new "volScalarField kinVisc":
class HerschelBulkley
    public viscosityModel
    // Private data
        dictionary HerschelBulkleyCoeffs_;
        dimensionedScalar k_;
        dimensionedScalar n_;
        dimensionedScalar tau0_;
        dimensionedScalar nu0_;
        volScalarField nu_;
        mutable volScalarField kinVisc_;
    // Private Member Functions
        //- Calculate and return the laminar viscosity
        tmp<volScalarField> calcNu() const;
and in the constructor of the HerschelBulkley class it is defined the same as "nu_"
    const word& name,
    const dictionary& viscosityProperties,
    const volVectorField& U,
    const surfaceScalarField& phi
    viscosityModel(name, viscosityProperties, U, phi),
    HerschelBulkleyCoeffs_(viscosityProperties.subDict(typeName + "Coeffs")),
    k_(HerschelBulkleyCoeffs_.lookup("k")),
    n_(HerschelBulkleyCoeffs_.lookup("n")),
    tau0_(HerschelBulkleyCoeffs_.lookup("tau0")),
    nu0_(HerschelBulkleyCoeffs_.lookup("nu0")),
    nu_
        IOobject
            name,
            U_.time().timeName(),
            U_.db(),
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        calcNu()
    kinVisc_
        nu_
I've tried alternative ways of defining kinVisc without copying nu_'s properties:
    kinVisc_
        IOobject
            "kinVisc",    //name
            U_.db(),    //U_.mesh(),
            IOobject::NO_READ,
        U_.mesh(),
        dimensionedScalar("kinVisc", dimensionSet(0, 2, -1, 0, 0, 0, 0), 0.01)
    //dimensionSet(0, 2, -1, 0, 0, 0, 0)
In the "calcNu()" function it looks like this:
Foam::tmp<Foam::volScalarField>
Foam::viscosityModels::HerschelBulkley::calcNu() const
    dimensionedScalar tone("tone", dimTime, 1.0);
    dimensionedScalar rtone("rtone", dimless/dimTime, 1.0);
    tmp<volScalarField> sr(strainRate());
 // return
 //     min
 //         nu0_,
 //         (tau0_ + k_*rtone*(pow(tone*sr(), n_) - pow(tone*tau0_/nu0_, n_)))
 //        /max(sr(), dimensionedScalar("VSMALL", dimless/dimTime, VSMALL))
    /*return
        min
            nu0_,
            (tau0_*(1.0-exp(-m_*tone*sr())) + k_*rtone*pow(tone*sr(), n_))
           /(max(sr(), dimensionedScalar ("VSMALL", dimless/dimTime, VSMALL)))
    Info << "test1" << endl;
    /*forAll(U_.mesh().cells(),celli)
        Info << "test2" << celli << endl;
        kinVisc_[celli] = 0.01;
        Info << "test3" << celli << endl;
    return kinVisc_;
Though it compiles without errors, the codes crashes when trying to return the kinVisc_ volScalarField.
Declaring kinVisc_ as a tmp<volScalarField> didn't work either.
Could anyone help me out here and tell me how it should be done correctly?
Thank you very much and best regards,
Lukas
zbtlfd is offline   Reply With Quote
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
make a dimensionedScalar to be volScalarField sharonyue OpenFOAM Programming & Development 4 April 2, 2014 06:44
multiplicate all elements of volScalarField with scalar to get new volScalarField maybee OpenFOAM Programming & Development 2 February 18, 2014 16:43
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 07:16
