Exporting some results data at text file format
Old   May 5, 2015, 18:07
Default Exporting some results data at text file format
Mehdi Asghari
Asghari_M is on a distinguished road
Hi all Foamers.
I have solved a 2D transient heat conduction problem by OpenFoam 2.3.1. Now, I’m going to write a text programing file (can be written at any programing language, for example, MatLab or FORTRAN).
The specifications of this program have been presented as follows:
Input: The geographical coordinates of a desired point into the solid material.
Output: The temperature of that specified point (it’s better to consider temperature interpolation of neighboring cells)
This program may be structurally similar to the following one:
Read (*,x , y); /***input***/
T=….
Write (T, temp.txt); /****Output*****/
END
Can anybody have any idea for this program file writing(for finding output)?
Cheers;
Asghari_M is offline   Reply With Quote
Old   May 6, 2015, 07:59
dkxls's Avatar
Armin
dkxls will become famous soon enough
Originally Posted by Asghari_M View Post
Hi all Foamers.
Cheers;
You don't need to write any code to do this, just use the probeLocations utility in OpenFOAM. You can find an example in this tutorial:
tutorials/lagrangian/reactingParcelFoam/parcelInBox
If your number of probe locations is not too big, you could also do this during run time to get a higher temporal resolution. You would use the probe functionObject to do that, for an example see this tutorial:
tutorials/incompressible/pimpleFoam/TJunction
dkxls is offline   Reply With Quote
Old   May 6, 2015, 11:38
Mehdi Asghari
Dear Armin,
Thanks for this great idea. That is definitely helpful.
Of course, I haven't still examined your suggested functions and tutorials. However, I need to save the temperature of specified location in terms of time at a text format.
For example, the text file can be such as following ones:
In the step number form:
(300,1)
(300.05,2)
Or at time step following:
(300,0.001)
(300.05,0.002)
The reason for above format is this fact that I need to use that probed temperature as an input for MatLab software in term of time.
I'd appreciated for any idea to do this task.
Old   May 6, 2015, 12:51
dkxls's Avatar
Armin
That's exactly what I have just explained to you. Check the tutorial!
Old   May 6, 2015, 17:46
Default I didn't find any output for that Location
Mehdi Asghari
Ok, I added a probesDict file at system folder.
However, I didn't find any output in my case folder.
My probesDict presented as follows:
FoamFile
    version         2.0;
    format          ascii;
    class           dictionary;
    location        system;
    object          probesDict;
// Fields to be probed. runTime modifiable!
fields
    T
// Locations to be probed. runTime modifiable!
probeLocations
    (0.1 0.0 0.250)
However, I couldn't find any post-processing data for this probed location(point).
Where can I observe the output probed data in?
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 18:25
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 14:14
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
