April 16, 2015, 17:34 |
Compile a new twoPhaseEulerFoam solver
Rep Power: 12 |
Got an error when I try to compile my own twoPhaseEulerFoam solver: "No rule to make target 'newtwoPhaseEulerFoam.dep', needed by 'Make/linux64GccDPOpt/dependencies'. Stop" I basically followed the instruction: http://www.tfd.chalmers.se/~hani/kur...tersReport.pdf After I coped the original solver, I changed in Make/files EXE = $(FOAM_APPBIN) by $FOAM_USER_APPBIN However there are several: "-I../" in differnt options files, should I change all of them to "-I$(LIB_SRC)/../applications/solvers/multiphase/twoPhaseEulerFoam" My version is 231 Thank you. Mingzhao |
April 17, 2015, 03:46 |
ali alkebsi
Rep Power: 14 |
did you do the following to
in Make/files newtwoPhaseEulerFoam.C EXE = $(FOAM_USER_APPBIN)/newtwoPhaseEulerFoam where newtwoPhaseEulerFoam is the name of your executable .C and the folder that contains it saved in home/userOFversion/applications/solvers and did you do wclean before the wmake you change the options file only when you have new libraries or models in the src or elsewhere (apart from the original ones) |
April 17, 2015, 13:36 |
Rep Power: 12 |
Hi kebsiali,
Thank you for explaining I did what you said and checked it again. Finally found out one letter is not capital so the compile didnt go through. Thank you very much any way. Mingzhao |
different results between serial solver and parallel solver | wlt_1985 | FLUENT | 11 | October 12, 2018 09:23 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
Creating New Solver: For particle-laden compressible jets | sankarv | OpenFOAM | 0 | April 4, 2010 19:06 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 15:08 |
TwoPhaseEulerFoam | newbee | OpenFOAM | 0 | March 27, 2006 09:41 |
