April 12, 2015, 06:20 |
How to make ManualInjection time dependent
Rep Power: 14 |
Hi everyone,
I am now modifying the ManualInjection model of OF2.3.1 to allow particleS of different properties to be injected at every timestep. I wrote a IOdictionary that allows the automatic rereading of particle postions, diameters and velocities. From the logfile below you can see that such a Dictionary is read at every timestep. However, the particles are not injected accordingly. Code:
regIOobject::readIfModified() : Re-reading object sprayCloudPositions from file "/home/carlen/OpenFOAM/carlen-2.3.1/carlenVOFLPT/run/VOFLPT/constant/Secondary/sprayCloudPositions" regIOobject::readIfModified() : Re-reading object sprayCloudVelocities from file "/home/carlen/OpenFOAM/carlen-2.3.1/carlenVOFLPT/run/VOFLPT/constant/Secondary/sprayCloudVelocities" regIOobject::readIfModified() : Re-reading object sprayCloudDiameters from file "/home/carlen/OpenFOAM/carlen-2.3.1/carlenVOFLPT/run/VOFLPT/constant/Secondary/sprayCloudDiameters" Courant Number mean: 2.4615003e-07 max: 0.0014217271 Courant Number mean: 3.7985957e-06 max: 3.924e-06 Max Courant Number: 0.0014217271 deltaT = 0.0001 Time = 0.0002 MULES: Solving for alpha.water Liquid phase volume fraction = 4.6875e-05 Min(alpha1) = 0 Min(alpha2) = 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for T, Initial residual = 1.5245762e-07, Final residual = 2.5596714e-13, No Iterations 1 min(T) 300 GAMG: Solving for p_rgh, Initial residual = 0.85150808, Final residual = 0.0021843274, No Iterations 3 max(U) 1.3741028 min(p_rgh) 99764.018 GAMGPCG: Solving for p_rgh, Initial residual = 0.079965064, Final residual = 5.2407171e-08, No Iterations 5 max(U) 0.17640096 min(p_rgh) 99987.999 Solving 3-D cloud sprayCloud Cloud: sprayCloud Current number of parcels = 0 Current mass in system = 0 Linear momentum = (0 0 0) |Linear momentum| = 0 Linear kinetic energy = 0 model1: number of parcels added = 0 mass introduced = 0 Parcels absorbed into film = 0 New film detached parcels = 0 Parcel fate (number, mass) - escape = 0, 0 - stick = 0, 0 Temperature min/max = 0, 0 Mass transfer phase change = 0 D10, D32, Dmax (mu) = 0, 0, 0 Liquid penetration 95% mass (m) = 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 3.8920766e-09, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 4.420232e-09, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 3.9743131e-09, No Iterations 2 DILUPBiCG: Solving for O2, Initial residual = 0.00083242377, Final residual = 4.3944334e-08, No Iterations 1 DILUPBiCG: Solving for H2O, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for h, Initial residual = 0.00059659358, Final residual = 1.245717e-08, No Iterations 1 T gas min/max = 300, 300 GAMG: Solving for p, Initial residual = 0.99999999, Final residual = 0.050075538, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 9.8099024e-08, global = -2.729417e-16, cumulative = -2.729417e-16 GAMG: Solving for p, Initial residual = 0.024331341, Final residual = 1.2388827e-07, No Iterations 4 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 9.8098944e-08, global = -2.7209419e-16, cumulative = -5.4503589e-16 smoothSolver: Solving for epsilon, Initial residual = 0.058494388, Final residual = 1.5872662e-10, No Iterations 2 smoothSolver: Solving for k, Initial residual = 1, Final residual = 4.525064e-09, No Iterations 2 ExecutionTime = 347.26 s Thank you in advance, carlen |
May 17, 2016, 09:37 |
Ali
Rep Power: 13 |
Hi Carlen
I'm stuck on a similar problem as you. I'm wondering how you managed to make the solver re-read the dictionaries? Would you be able to share the code for doing so please? Ali |
June 8, 2016, 00:35 |
#3 | |
Ping Chang
Rep Power: 10 |
I met the same problem as you, The particles' information always same as the first step. I have no idea what's going on. Have you solved your problem? Ping |
September 12, 2016, 04:53 |
Ali
Rep Power: 13 |
Hi Ping
No I haven't. I'll post up if I do though. Have you managed? Ali |
March 2, 2018, 19:00 |
Rep Power: 11 |
Has anyone successfully solved this problem? I also want to inject particles at different points in time. Say, for instance at t = 0, i.e., initially 20 particles get injected into the domain. In the next time step, no particle is injected. In the third time step, around 5 particles get injected and so on. I have a file which has data concerned with the number of particles injected at different time steps. How can I sync this with manual injection in OpenFOAM? In a nut shell, instead of specifying the position, I want to specify the time when a particle gets injected into the domain. Any suggestions / advice in this regard is greatly appreciated!! Thanks!! Best, Scram_1 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 05:13 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 03:34 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 08:56 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 05:26 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
