How can I get the field-value at previous two time-steps
Old   April 1, 2015, 20:13
Default How can I get the field-value at previous two time-steps
lqiao19
duanjianxian is on a distinguished road
Hi, formers!
I want to predict the value of a scalar-field at the runTime using its at the previous two time-steps. In a mathematical expression, it can be expressed like F(n+1)=2*F(n)-F(n-1).
In openFOAM, I know that creatField can read and write the values in the running. So, the previous two time-steps maybe can read by IOobject from time-named folder. But, I don't want to write the field at all steps.
Are there some skills to realize this but no writing in every step?
Thanks for your attention!
Best wishes for you!
duanjianxian is offline   Reply With Quote
ioobject, openfoam, read fields, solver
How to export time series of variables for one point? mary mor OpenFOAM Post-Processing 8 July 19, 2017 11:54
Simulation seems to converge but crashes suddenly xxxx OpenFOAM 16 September 12, 2014 09:07
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 05:35
