2D average source from a 3D flow simulation
Old   March 31, 2015, 06:10
Default 2D average source from a 3D flow simulation
wc3speler is on a distinguished road
Hi everyone!
Suppose I do a 3D flow calculation where a term volVectorField div(U*U) is being calculated. I would like to average this volume term in the spanwise direction, i.e. the result being a volume field in a 2D plane (1 cell thick) which can be output like a normal field. How can this be coded?
The context is that I first want to do a turbulent flow simulation in 3D and then later use the recorded span-wise averaged acoustic source for a 2D acoustic simulation (sound pressure levels can be corrected afterwards).
Kind regards,
Jurriaan
wc3speler is offline   Reply With Quote
3d to 2d, aero-acoustics, average field
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 16:14
Help! Incompressible flow simulation source code. C.B. Jiang Main CFD Forum 3 July 18, 2000 09:01
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
