Stream-wise periodic heat transfer using fvOptions |
March 30, 2015, 04:02 |
#1 | |||
Jakob Hærvig
Rep Power: 14 |
Dear all,
I modelling fully developed flow in a pipe having streamwise periodic dimensions. I am to investigate heat transfer and pressure drop characteristics. The momentum equation is corrected using the fvOptions: Quote:
Best, Jakob Last edited by hrvig; March 30, 2015 at 11:47. |
March 30, 2015, 09:47 |
#2 | |
Jakob Hærvig
Rep Power: 14 |
Did anyone make the temperature distribution cyclic using the fvOptions functionality of OpenFOAM 2.2?
The temperature can be considered as a passive scalar and therefore the energy equation is not solved. For the velocity I added a source term to the momentum equation using Quote:
Best, Jakob |
April 3, 2015, 13:31 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Jakob,
I've moved your 2nd post from another thread: http://www.cfd-online.com/Forums/ope...m-2-2-2-a.html - because it was a bit out of context back there. Technically, the answer to your second post is: the "fvOption" "pressureGradientSource" only changes the pressure and flow fields, it does not affect directly all other fields. As for your question from both posts, it seems you've managed to solve this issue, according to what you wrote on this thread: http://www.cfd-online.com/Forums/ope...tml#post539477 - posts #8 and onward Best regards, Bruno |
April 3, 2015, 17:56 |
Jakob Hærvig
Rep Power: 14 |
Hi Bruno,
Sorry for bring unclear. What I actually wanted to do was to use the new fvOptions to change a passive scalar field. I found options such as "scalarcodedsource" which I guess could do what I needed. Anyway, I guess modifying the solver directly is still the way to go in most cases. Best, Jakob |
March 21, 2017, 11:13 |
I have the same need. Have you solved this issue?
March 22, 2017, 09:17 |
Agustín Villa
Rep Power: 15 |
Hello
what you can do is to use a semiImplicitSource, but first you need to know your heat flux, so you can get an idea of the input power. If you are working without density and specific heat capacity, then divide your heat source value by them, and use it in your fvOptions. I hope that it would be helpful. PS: hello Edoardo |
March 22, 2017, 11:39 |
Hi agustinvo, thanks! Let's continue on the other discussion:
Heat source using fvOptions in laplacianFoam Ps. Ciao Agustin!!! |
cyclic heat transfer, periodic heat transfer |
High values of heat transfer coefficient for laminar flow in pipe | Allankey | CFX | 2 | May 28, 2014 13:44 |
Porous domain:Interfacial area density and heat transfer coefficient | l.te | CFX | 2 | May 18, 2014 00:45 |
Boussinesq with periodic heat transfer | kiurigan | FLUENT | 0 | December 5, 2013 13:22 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
periodic flows and heat transfer? | scarecrow | FLUENT | 3 | December 2, 2003 01:59 |
