Add Temperature to multiphaseInterFoam
Old   March 12, 2015, 17:47
Default Add Temperature to multiphaseInterFoam
Nicolas Thiers
nthiers is on a distinguished road
Hi everyone, am new with openfoam and for my thesis i have to study a 3-phase fluid (oil+water+air) so i'm using multiphaseInterFoam, but i need to add temperature to my solver, so i follow the tutorial avaible for the icoFoam solver but now i need to add the multiphase effect to this ecuation.
i figure that it can be done treating DT (Thermal diffusivity) in the same way that rho but im not really sure how do i have to change the code or where is calculated the rho field as a mean weight by the volumes fraction.
if anyone could help me i will be really appreciate
Nicolas
nthiers is offline   Reply With Quote
Old   March 13, 2015, 05:32
Ramon
RjwV is on a distinguished road
Hello Nicolas,
Have you ever looked in the twoPhaseEulerFoam solver? It is for two phases, but it contains energy equations for both phases, heat exchange between them, etc... Perhaps it could inspire you?
Kind regards,
Ramon
RjwV is offline   Reply With Quote
Old   March 25, 2015, 09:18
Nicolas Thiers
hi RjwV thanks for your help, i was actually looking at compresiblemultiphaseinterfoam and it helps me a lot. Now i have another problem, how can i add a new propertie to each phase? i modified the phase.h and the phase.c to add a new propertie DT but i cant compile, here are my two files:
phase.h
#ifndef phase_H
#define phase_H
#include "volFields.H"
#include "dictionaryEntry.H"
#include "incompressible/viscosityModels/viscosityModel/viscosityModel.H"
namespace Foam
                           Class phase Declaration
class phase
    public volScalarField
    // Private data
        word name_;
        dictionary phaseDict_;
        autoPtr<viscosityModel> nuModel_;
        dimensionedScalar rho_;
        dimensionedScalar DT_;
public:
    // Constructors
        //- Construct from components
        phase
            const word& name,
            const dictionary& phaseDict,
            const volVectorField& U,
            const surfaceScalarField& phi
        //- Return clone
        autoPtr<phase> clone() const;
        //- Return a pointer to a new phase created on freestore
        //  from Istream
        class iNew
            const volVectorField& U_;
            const surfaceScalarField& phi_;
        public:
            iNew
                U_(U),
                phi_(phi)
            autoPtr<phase> operator()(Istream& is) const
                dictionaryEntry ent(dictionary::null, is);
                return autoPtr<phase>(new phase(ent.keyword(), ent, U_, phi_));
    // Member Functions
        const word& name() const
            return name_;
        const word& keyword() const
            return name();
        //- Return const-access to phase1 viscosityModel
        const viscosityModel& nuModel() const
            return nuModel_();
        //- Return the kinematic laminar viscosity
        tmp<volScalarField> nu() const
            return nuModel_->nu();
        //- Return the laminar viscosity for patch
        tmp<scalarField> nu(const label patchi) const
            return nuModel_->nu(patchi);
        //- Return const-access to phase1 density
        const dimensionedScalar& rho() const
            return rho_;
	//- Return const-access to phase1 DT
        const dimensionedScalar& DT() const
            return DT_;
        //- Correct the phase properties
        void correct();
        //- Read base transportProperties dictionary
        bool read(const dictionary& phaseDict);
} // End namespace Foam
#endif
phase.c
#include "phase.H"
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::phase::phase
    const word& phaseName,
    volScalarField
        IOobject
            IOobject::groupName("alpha", phaseName),
            U.mesh().time().timeName(),
            U.mesh(),
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        U.mesh()
    name_(phaseName),
    phaseDict_(phaseDict),
    nuModel_
        viscosityModel::New
            IOobject::groupName("nu", phaseName),
            phaseDict_,
            U,
            phi
    rho_(phaseDict_.lookup("rho"))
    DT_(phaseDict_.lookup("DT"))
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
Foam::autoPtr<Foam::phase> Foam::phase::clone() const
    notImplemented("phase::clone() const");
    return autoPtr<phase>(NULL);
void Foam::phase::correct()
    nuModel_->correct();
bool Foam::phase::read(const dictionary& phaseDict)
    phaseDict_ = phaseDict;
    if (nuModel_->read(phaseDict_))
        phaseDict_.lookup("rho") >> rho_;
        phaseDict_.lookup("DT") >> DT_;
        return true;
    else
        return false;
when i try to compile the library multiphaseMixture, it fails in the DT_(phaseDict_.lookup("DT")) line and shows the error:
wmake libso multiphaseMixture
Making dependency list for source file phase/phase.C
SOURCE=phase/phase.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IalphaContactAngle -I/opt/openfoam230/src/transportModels -I/opt/openfoam230/src/transportModels/incompressible/lnInclude -I/opt/openfoam230/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam230/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/phase.o
SOURCE=multiphaseMixture.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IalphaContactAngle -I/opt/openfoam230/src/transportModels -I/opt/openfoam230/src/transportModels/incompressible/lnInclude -I/opt/openfoam230/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam230/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/multiphaseMixture.o
phase/phase.C: En el constructor ‘Foam::phase::phase(const Foam::word&, const Foam::dictionary&, const volVectorField&, const surfaceScalarField&)’:
phase/phase.C:65:5: error: expected ‘{’ before ‘DT_’
phase/phase.C: En el ámbito global:
phase/phase.C:65:8: error: expected constructor, destructor, or type conversion before ‘(’ token
make: *** [Make/linux64GccDPOpt/phase.o] Error 1
make: *** Se espera a que terminen otras tareas....
i will appreciate your help
Nicolas
Old   March 25, 2015, 12:22
ali alkebsi
kebsiali is on a distinguished road
Hello there,
Have you seen these
http://www.cfd-online.com/Forums/ope...interfoam.html
http://www.wolfdynamics.com/images/conf_and_publ/interTempFoam.pdf
http://www.wolfdynamics.com/images/conf_and_publ/source_interTempFoam.tar.gz
kebsiali is offline   Reply With Quote
Old   March 30, 2015, 17:02
Nicolas Thiers
hi kebsiali thx for your answer, yes am already see them and they didnt help me with my problem, speacialy because multiphaseinterfoam has many diferences with interfoam, specially in the library, i couldnt extend that example to multiphaseinterfoam.
have you read my last message? have any idea why its giving me that error when i try to compile te library?
Thanks for your time and help!
Old   March 30, 2015, 17:41
Nicolas Thiers
Thanks every one for your help, finally i could make it work, i found the error, forgot to put "," at the end of the rho_(phaseDict_.lookup("rho")) line.
    rho_(phaseDict_.lookup("rho")),
Old   February 17, 2016, 09:42
Default multiphaseinterfoam with temperature and extra transport properties
Thomas Flint
tom_flint2012 is on a distinguished road
Hi nthiers,
I am also attempting to add temperature to multiphaseinterfoam. I have modified the phase.h and phase.c files as you suggested. I have also modified the multiphasemixture . and .c files. Is this necessary? I cant even get the solver to read in an extra transport property at this time. I am defining a volscalarfield kappasolid and using mixture.kappasolid() bu getting an "undefined reference" call. Did you just modify the phase files and if so how did you call your DT variable in your code if you dont mind me asking
Best regards,
Tom
tom_flint2012 is offline   Reply With Quote
multiphaseinterfoam, temperature field
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 07:36
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 10:23
Ansys Structural Environmental Temperature zytra Structural Mechanics 0 October 31, 2014 15:32
Free stream temperature saharesobh FLUENT 1 October 11, 2012 21:52
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
