February 26, 2015, 01:06 |
twoPhaseEulerFoam-bubble column
JISHNU H
Rep Power: 12 |
Dear FOAMERS,
As part of my Master project, I am supposed to do saturated flow boiling simulation using OpenFOAM. I have selected twoPhaseEulerFoam as the base solver. I am planning to introduce heat transfer coeffecient as one parameter. From a paper i referred, the the correlation includes a vapour quality term. But i dont know how I should introduce that term. Please help me. Thanks in advance |
March 1, 2015, 09:16 |
twoPhaseEulerFoam- bubble column
JISHNU H
Rep Power: 12 |
FOAMERS,
please find some time to help me in explaining the physics behind the case bubblecolumn in twoPhaseEulerFoam. I am not able to get the science and hence not able to develop it into my work, i.e, saturated flow boiling simulation. Please help. Thanks in advance |
March 2, 2015, 00:19 |
JISHNU H
Rep Power: 12 |
FOAMERS,
I am currently working on twoPhaseEulerFoam for the simulation of saturated flow boiling. I dont have clear idea about the tutrial bubble column of twoPhaseEulerFoam and I am unable to find any tutorial decribing the problem. Please help me Thanks in advance |
March 10, 2015, 11:31 |
Error: while compiling twoPhaseEuler Foam
JISHNU H
Rep Power: 12 |
Hi all,
I am doing saturated boiling and while compiling my solver I am stuck with following errors. boilingModel.H: In function ‘int main(int, char**)’: boilingModel.H:19:87: error: cannot convert ‘Foam::dimensioned<double>’ to ‘double’ for argument ‘1’ to ‘double exp(double)’ dimensionedScalar dw = min(0.0014, 0.0006*::exp(-((Tsat.value()-T2[faceCelli])/45))); ^ In file included from twoPhaseEulerFoam.C:80:0: boilingModel.H:78:19: error: cannot convert ‘Foam::dimensioned<double>’ to ‘double’ in assignment mEvap[faceCelli] = (Qevap.value()/(hfg.value()+Cp2.value()*(Tsat.value()- T2[faceCelli])))/mesh.V()[faceCelli];//calculating evapoative mass transfer boilingmodel is a header file used to implement bubble characteristics. Please heklp me as I am stuck here. |
August 13, 2015, 05:43 |
Ramon
Rep Power: 12 |
Hello jishnuhari25,
I know it may be a little late, but here is my attempt to help you. First of all, try to avoid using integers in equations only containing doubles, so don't use "1" or "2", or in your case, "45". Try using 45.0 instead. Sometimes using an integer will try to force your entire equation to become an integer. Also, does "0.0006*::exp" work in other equations? Shouldn't it be 0.0006*Foam::exp or 0.0006*std::exp , depending on what you want to use? Not sure what the problem in line 80 could be. Kind regards, Ramon |
August 13, 2015, 07:13 |
Thanks!!!
JISHNU H
Rep Power: 12 |
Thank you very much for your reply.
I have completed my project somehow and it shows pretty good results. Thank you very much for spending your time in trying to resolve my problem. |
Problem: bubble column with twoPhaseEulerFoam | hester | OpenFOAM Running, Solving & CFD | 6 | January 22, 2016 13:25 |
Turbulence modelling for bubble column in twoPhaseEulerFoam | hester | OpenFOAM Running, Solving & CFD | 2 | February 10, 2015 12:42 |
2D bubble rising through a column of water | vof64 | Fluent Multiphase | 0 | August 20, 2014 00:42 |
twoPhaseEulerFoam Simulations of bubble column | vishal3 | OpenFOAM | 1 | July 7, 2014 05:12 |
twoPhaseEulerFoam : bubble column modeling | chittipo | OpenFOAM Running, Solving & CFD | 2 | June 11, 2012 07:12 |
