Old and new values of a field
Old   February 19, 2015, 18:07
Default Old and new values of a field
Franko is on a distinguished road
Hi, I have a problem with using old value of a field.
I have A and B - dimensionless volScalarFields
I also have
dimensionedScalar c ("c", dimensionSet(0, 0, 1, 0, 0, 0 ,0), 1.0);
In the beginning, I know A_i^n and B_i^n, i = 0,1,...,I
I want to solve two equations below in OpenFOAM (n - number of time layer):
1) A_i^{n+1} = 2*B_i^n;
2) \frac{A_i^{n+1}B_i^{n+1} - A_i^nB_i^n}{\tau} + B_i^{n+1} = 0
i = 0,1,...,I
(I want to find A_i^{n+1} from the first equation and then B_i^{n+1} from the second one)
I used this code with Euler scheme:
A = 2*B;
fvScalarMatrix BEqn
c*fvm::ddt(A,B) + fvm::Sp(1,B)
BEqn.solve();
The problem here with row
A = 2*B
This row let me find A_i^{n+1} but it also deleted old A_i^n values because OpenFOAM took the second equation as
\frac{A_i^{n+1}B_i^{n+1} - A_i^{n+1}B_i^n}{\tau} + B_i^{n+1} = 0
And I got the wrong decision!
What code will solve A_i^{n+1} = 2*B_i^n equation and won't delete old A_i^n values?
Thank you very much for any help ...
Franko is offline   Reply With Quote
Old   February 24, 2015, 07:42
Default simple equation
So, what will be the best way to solve the equations without any derivatives in OpenFOAM?
For example look at the equation A = 2B
(A and B - volScalarFields).
Do you use this code to solve it:
A=2*B;
Is that correct code?
Please help!
Old   February 27, 2015, 05:06
anonymous
ssss is on a distinguished road
Are you going to use always that kind of temporal discretization? If the answer is yes, you can access runTime delta T:
dimensionedScalar mydeltaT1("mydeltaT",dimensionSet(0, 0, 1, 0, 0, 0, 0),scalar(runTime.deltaTValue()));
And then solve manually the set of equations.
ssss is offline   Reply With Quote
