Adding directional forces to OpenFoam 2.3
Old   February 8, 2015, 15:18
Default Adding directional forces to OpenFoam 2.3
Matt Wright
mattwright1234 is on a distinguished road
I'm new to OpenFoam and I'm trying to model Acoustic Streaming using OpenFoam 2.3.0 for my third year undergraduate research project. I'm trying to add forces at different points on the mesh with varying magnitudes and directions that will change the direction and velocity of the flow. Is this possible and if so how can I do this?
Many Thanks
Matt
mattwright1234 is offline   Reply With Quote
Old   February 8, 2015, 16:21
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
You've got several possibilities, depending on your real needs (what was described in your post is too general). You can look at how gravity is implemented in buoyantBoussinesqPimpleFoam (or interFoam). Or you can go with fvOptions, look at pressureGradientExplicitSource as an example, then use codedSource to implement your own.
alexeym is offline   Reply With Quote
Old   February 8, 2015, 17:49
Matt Wright
Sorry, I'll specify more. I'm trying to add reynolds stresses to many different points on a '2D' mesh with different magnitudes and directions. I'm trying to model the flow when it's in a steady state.
[Commercial meshers] Problem with cyclic boundaries in Openfoam 2.3, mesh import from ICEM Scabbard OpenFOAM Meshing & Mesh Conversion 29 October 6, 2020 22:14
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
OpenFOAM Training in Europe and USA hjasak OpenFOAM 0 August 8, 2008 06:33
Strange results from interFoam solution converges but sum of all forces not equal to zero nicasch OpenFOAM Running, Solving & CFD 0 April 15, 2008 03:01
OpenFOAM Training and Workshop Zagreb 2628Jan2006 hjasak OpenFOAM 1 February 2, 2006 22:07
