Defining solid zone in interFoam
Old   February 6, 2015, 02:36
Exclamation Defining solid zone in interFoam
junewookee
junewookee is on a distinguished road
I tried to simulate the water droplet impinging onto flat surface using interFoam solver.
I countered some problems.
I know that interFoam deals with fluid flow only. So defining solid zone is hard for me.
I modified UEqn.H shown below.
SL(solid layer) is defined as volScalarField in createFields.H.
If SL is 1, then cell is considered as solid cell. So there's no velocity values in solid cell.
If SL is 0, then the cell is considered as fluid cell. So momentum equation will be calculated.
@ UEqn.H
fvVectorMatrix UEqn
fvm::ddt(rho, U) * pos (0.01 - mag(fvc::interpolate(SL)))
+ fvm::div(rhoPhi, U) * pos (0.01 - mag(fvc::interpolate(SL)))
- fvm::laplacian(muEff, U) * pos (0.01 - mag(fvc::interpolate(SL)))
- (fvc::grad(U) & fvc::grad(muEff)) * pos (0.01 - mag(fvc::interpolate(SL)))
UEqn.relax();
if (pimple.momentumPredictor())
solve
UEqn
fvc::reconstruct
fvc::interpolate(interface.sigmaK())*fvc::snGrad(a lpha1) * pos (0.01 - mag(fvc::interpolate(SL)))
- ghf*fvc::snGrad(rho) * pos (0.01 - mag(fvc::interpolate(SL)))
- fvc::snGrad(p_rgh) * pos (0.01 - mag(fvc::interpolate(SL)))
) * mesh.magSf()
When i compile the modified solver, the error message came out like this.
'no match for 'operator*' ..... '
at the first transient term of momentum equation (bold and italic fonts)
I want to know why this is wrong.
Thank you.
Sincerely.
junewookee is offline   Reply With Quote
drop impact, interfoam, solid zone
Error in solution using "Grid Interface" agustinvo FLUENT 4 January 20, 2015 13:03
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 12:25
Defining Rotor Zone NTM FLUENT 1 September 4, 2008 03:03
UDS in solid zone shuqin FLUENT 0 May 6, 2006 05:56
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 09:42
